Old 06-27-2012, 10:04 PM   #11
Just wanted to update this thread....
I found the problem with my fridge, furnace, and bunkhouse lights...
I knew the issue had to be wiring since the trouble was isolated to this area of the camper.
we had checked the fuses and visible wiring.... but i went to check -for the 4th time- the fuses and as I grabbed the fuse for fridge/furnace, the bunkhouse lights came on...??? The fuse was ok.... the soldered pins of the fuse housing were loose...
So I moved the wire from this fuse to an open, unused fuse and everything works.
Brad & Melissa
2002 Ford Expedition 4X4 4.6 ltr
1999 ForestRiver Flagstaff 829BHS
braddaddy is offline   Reply With Quote
