05-06-2017, 10:00 AM
Help!! Grey tank shows full
So on our first run with our TT the forest river signature series 8328BS. Well we hooked up to a full rv site. Got everything running draining properly.... after first and only shower system read "grey tank" 2 full!!! Confused as all get out when out to drain and made sure valves were open and nothing came out?? Anyone have this problem before???
05-06-2017, 10:11 AM
Don't know your model and cant look it up right now but any chance you have 2 gray tanks?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
05-06-2017, 10:12 AM
Since you have a 108 gallons total grey tank, you must have two grey tanks, so have you open two grey tank valves? You would have a total of 3 valves on your trailer (1 black, 2 greys)
Fonzie
05-06-2017, 10:15 AM
On my 5th wheel, 2nd valve is on frame behind rear tire, drivers side
05-06-2017, 10:30 AM
there may be several reasons for that reading. Like others have said check and ensure if you have a second tank that the valve for it is open. (black should be left closed until tank full just saying). If all valves are correct it may be as simple as some hair and soap scum on sensor try filling the tank and flushing it and see what happens. Let the forum know what you find even if it embarrassing we have all been there.
Retired Navy
2016 Flagstaff 26 FKWS
05-06-2017, 10:47 AM
Correct i have 2 grey tanks. Both valves are open.... the black valve is closed. Granted we only do number 1 in the toilet. BUT this our first outing with it and one shower would not put 108 gallons . Ya im just confused makes no sense.....
life is good!
05-06-2017, 11:03 AM
Well you'll learn you can't trust the sensors. Are you sure it's full? I realize you said you opened the valve and nothing came out but usually a full grey tank will back up in the shower.
Also maybe the valves are marked or connected incorrectly.
Since you are at a full hook up site, check to be sure the black tank valve isn't by chance one of the greys. Open them all and run water or flush toilet and see which one the water comes out.
A few drops of food coloring in the drain helps determine which is which.
05-06-2017, 12:02 PM
On my trailer they reversed the sensor wires from the tanks with black labeled as grey, etc.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
05-06-2017, 12:24 PM
Regardless of what sensor reads, OP says nothing comes out after taking a shower. Maybe 5Picker is correct with the mislabled valves. On my trailer the black valve has a much larger pipe leading to it than the grey if that would help identify the two.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
05-06-2017, 12:26 PM
Carknocker Family
Are your valves cable operated or hands on? If cable, it may have broke /came off, or not installed correctly. First use, right?
If hands on operated, is the handle still moving blade inside valve?
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
05-06-2017, 12:49 PM
Drain Valves
Try here for you drain valves:
Look under the front slide about center. It is hard to reach when the slide it out. Should be marked on the body. The "T" handle pulls toward the side not straight out.
A grey and a Black should be behind the rear tires.
05-06-2017, 01:50 PM
Never , ever trust the gauges . Also save some grey water to flush the black water flush hose !
05-06-2017, 02:29 PM
As others have stated, don't ever trust the sensors. I always trust my wife's visual and audio sensors which go like this; "Honey! The water's not draining in the sink." And I reply; "I'll go right out and drain the tank." Works every time!
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
05-06-2017, 03:29 PM
May have been some water left in from when it was checked.
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
05-06-2017, 11:00 PM
Mine are manually operated. Yes the valve is opening. Sadly stuffed my hand in there to verify.. with gloves of course. I came back from a wheelin trip and the tank registered empty?? Ya im so lost... lol
05-08-2017, 08:20 AM
I third this!
05-08-2017, 02:31 PM
Originally Posted by RV_Fan44
I third this!
I 4th this! Lol!
05-17-2017, 12:59 PM
LOVED THIS... Yes the DW is Always right....
Thanks for the chuckle...
This is DW/Debbie
2017 Flagstaff Super Lite - 832IKBS - Diamond Package
2006 GMC Sierra 2500HD
Been an RV owner since 2003
