Old 03-07-2017, 09:31 PM   #21
ARLO
I used 1/4" (I believe) bolts with lock nuts and washers.
rlocicero is offline   Reply With Quote
Old 03-07-2017, 09:50 PM   #22
SailorSam20500's Avatar
No idea how they will hold up, but you can get rivets. Here is a link to some aluminum ones. $15 for 100 (think lifetime supply). Insert and pound away to peen the head.
Solid Aluminum Rivets - 1/4 to 3/8 | Solid Aluminum
Site has rivets in other metals, but stainless is probably harder to work with.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 03-08-2017, 08:00 AM   #23
I used the bolt method on ours until we got to Goshen then Cedar Creek was nice and replaced them with the 4 step model
dblr is offline   Reply With Quote
Old 03-08-2017, 01:16 PM   #24
Tanddhall's Avatar
Bolt broke
Originally Posted by doc73 View Post
One of the rivots on our front entry steps is wearing out allowing the steps to get out of the track when opened and closed. Any ideas on a repair solution?
I was thinking a small hex bolt with lock washer and washers? I dought I would find a new large rivot let alone the tool to do the rivet. Pics bellow for reference.
20170306_162516 by doc736, on Flickr
20170305_151208 by doc736, on Flickr
One of mine completely broke off while my son-in-law, holding my grandson, causing him and the step to hit the ground. Luckily no one was hurt. Easy fix is like others have said, drill out the old parts and place a grade 8 bolt, washer and self locking bolt. Go ahead and to this with all of the same points on the steps as all are in the same process of failing.
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
