Old 06-01-2019, 06:11 PM   #1
Help! Replacing heater duct under floor
Hello!
2003 Wildwood T23BH travel trailer. Duct in the floor requires replacement. This spring i found that mice got into the trailer over the winter and made a mess. Bleached everything etc... Found the mice were in the floor duct. Well, the floor duct never moved air properly anyway, so today I removed the fresh water tank, and cut open the tarp-type stuff for the underbelly. The duct is made of foil backed fiberglass insulation. Fiberglass is on the inside of the duct making it impossible to properly clean it. So I pulled it all out and tossed the mess in the garbage. Found the mice got into the tarp-like underbelly and found the duct, where they chewed thru the foil and made a nest in the rear of the duct.
My problem is, what to use a suitable duct material? There are a couple of frame crossmembers that I have to cross over, and the height between the crossmember and the underside of the plywood floor appears to be about 2-3/4" I could use the aluminum dryer duct and crush it to fit, but i'm not sure about insulation. Do I crush the duct and use spray foam to insulate? do i use duct that comes with insulation? Do I try and fabricate a new duct with sheet metal and glue fiberglass to the underside? Pics are attached for clarity.
Thanks for any input!
Overall Pic
Plenum under furnace
Front Register
Middle Register
Rear Register
Crossmember to floor clearance
Ozzmosis is offline   Reply With Quote
Old 06-01-2019, 11:16 PM   #2
Iwannacamp's Avatar
Imo. You have a few options. The best isnít the cheapest. Call/google/ask around for someone who does sheet metal work. They will have or can build metal duct insulated on the inside and you put together and install.
The next option is cheaper. Get some duct board from an HVAC wholesaler. They should sell it to you...most of the time if you pretend you know what you are doing. I think itís about $30 a sheet 5 x 10 feet I think. Downside is you really need a duct kerfing tool like this
To cut the kerf out so you can fold it. You can do it with a box knife, a 1x4 straight edge, some patience and practice. It ainít rocket science. The measuring is the hardest part starting out. The duct board around here is 1Ē or thicker so it will use some of your space. Duct board tape(not duct tape) and some patience. I havenít tried, but I am sure there are boocoo YouTube videos about it.
I will help if I can on info.
2017 Puma 297RLSS
floor, heater
