Old 10-13-2010, 05:54 PM   #1
Help! What is this?
I just purchased a 2005 38' Salem Travel Trailer. As I was exploring under the trailer I came across this... the long rectangular box with the 2 hoses hanging down. It is just in front of the fresh water thank. Can anybody tell me what it is?
denboot is offline   Reply With Quote
Old 10-13-2010, 06:01 PM   #2
daverain's Avatar
They are your hot and cold water low point drains generally opened when you winterize.
Dave and Rainy
daverain is offline   Reply With Quote
Old 10-13-2010, 06:51 PM   #3
And what I did was mark the hot water side with red tape and the cold water side with blue tape just so I would know which was which. For some reason I like to color code things.
Old 10-14-2010, 02:04 PM   #4
Thank you. That's what I thought, but wanted to make sure.
Old 10-14-2010, 03:28 PM   #5
KyDan's Avatar
Welcome to the forums!
Hope you stick around and add your 2˘ every so often!!
There is a wealth of info here.
I can't count the number of times I've found answers or good
ideas here that helped me in my RVing.
Happy Camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 10-14-2010, 09:17 PM   #6
Wanna Be Camper
SaskCampers's Avatar
Welcome to the forum, glad to see you have your answer already..
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-15-2010, 05:59 AM   #7
3 Happy Campers's Avatar
They located my L.P.D.s square in the center of the bottom of the 5er.
$5 worth of PVC & no more crawling on my belly.
Also added a ball valve to my fresh water drain.
Name:	Low Point Drains a.jpg
Name:	Low Point Drains d.jpg
3 Happy Campers is offline   Reply With Quote
Old 10-15-2010, 07:21 AM   #8
MtnGuy's Avatar
OK, I think I would have a problem if my fresh water system low point drains are located below the black water dump tank. I know, I know, that the valves are closed, the system is usually pressurized and all of that, but it just don't seem right.
Is there any way to run the lines a different direction ??
Old 10-15-2010, 07:36 AM   #9
If your point is contamination, I really don't think that’s possible.
The valves are 3 + feet from the end of the sewer boom & with the hose extended the valves would be from 3' to 10' more away.
Here’s a full pic of the boom for comparison.
Would really have to be slinging the “stuff” around for it to come in contact with the drains.
Name:	Lippert Sewer Management System.jpg
Old 10-15-2010, 11:48 AM   #10
Villa Estate 392FLFB
The_Stuff's Avatar
I have the 392flfb 42' model. I have the same box and same low point hoses underneath. my lines are colour coded red and blue throughout the trailer and they are in the same place. I gotta put some insulation up there soon. the factory stuff doesnt keep it that insulated on cold mornings!
One state/province at a time!
The_Stuff is offline   Reply With Quote
