Old 04-22-2016, 12:54 PM   #1
Help with bumper grill mount
Hi everyone, I am out at a campground right now and thought I would attach the grill to the mount that came on this trailer. But I can't figure out what is missing (if anything) to mount this thing. Can anyone help me figure out what I need? Do I need to drill a hole and use nuts and bolts to mount this or is there something else that is supposed to come with this set up.
Thanks!
Eric
ID:	105730   Click image for larger version
2016 Palomino Solaire GT3 315RLTSEK
2005 Dodge 2500 Cummins
Ewehrum is offline   Reply With Quote
Old 04-22-2016, 01:51 PM   #2
B47
Didn't you get an instruction sheet with the kit? If not,you might call the manufacture for one or Goggle for one.
Until you know what to do,don't drill any holes.
Old 04-22-2016, 02:08 PM   #3
I got the instructions manual and the only thing it says is how to mount the grill itself to the bracket, but not how to mount the bracket to the mount that's attached to the bumper. I'll try to dig further online for this mount and see what I can find. Thank you!
Old 04-22-2016, 07:40 PM   #4
The last grill i had was not a permanent mount but I had to take it on and off the number monte very time I used it. There were basically3 parts. The bumper mount, the bracket that attached to the mount and grill, and the grill.
Dinostop is offline   Reply With Quote
Old 04-22-2016, 09:05 PM   #5
HONDAMAN174's Avatar
Looks like the white "reversed c channel" should go over your top edge then slide in underneath. No different than a BBQ rail of a sidekick grill.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 04-22-2016, 09:43 PM   #6
Looks like the Aussie grill we have on our Palomini. All you so is slip the top channel over the backplate. The weight of the mounted grill keeps it from moving around. We have had our trailer a couple of years now and while the grill is somewhat bouncy nothing has broken and it is secure enough for its intended purpose.
keith_h is offline   Reply With Quote
Old 04-22-2016, 10:17 PM   #7
So I am assuming this particular mount can't be used while in travel like some of the others
Old 04-22-2016, 10:22 PM   #8
I don't understand your question about being used while in travel. If you mean can it be left mounted while driving so you can just stop and start grilling, no it needs to be stowed each time you move the trailer. Even if you were to add bolts the frame isn't strong enough to handle the weight and flexing you get while driving.
Old 04-22-2016, 11:26 PM   #9
Yep that's what I meant. Thank you for clarifying that!
Old 04-23-2016, 08:11 AM   #10
Some Forest River campers have grills that are designed to stay on while traveling.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
mount
