Old 06-14-2009, 10:49 AM   #1
UNIT6AUBURN's Avatar
Question Here's one for you................
Went camping friday air conditioner worked fine,strong thunderstorm went north of us friday night,but didnt hit us. AC went out early sat morning about 3 am.fan works as does everything else but ac wont come on.It tries to but sounds like the compressor wont kick in,AND it trips the breaker in the camper.Came home today and plugged it in at house and when you turn on the fan it works, but switch to air conditioner it trips the breaker in the house, every time.
UNIT6AUBURN is offline   Reply With Quote
Old 06-14-2009, 11:01 AM   #2
NWJeeper's Avatar
Sounds like the compressor may be seized up. A/C units are very picky about propper voltage as well as free air flow. Any A/C unit should only be run with all of its outlets open whether ducted or not and have a clean intake filter. If the A/C cannot flow freely the compressor will heat up and seize. If it isn't a seized compressor then have the starting capacitor checked as they can and do go bad although it is rare. We had the starting capacitor go out on our home A/C unit and the symtom you discribe was close to the same.
Ed & Wendy
www.nwjeepn.com
Old 06-14-2009, 03:36 PM   #3
I have taken the cover off the ac and the compressor is not kicking in, I guess it is the compressor(tall black tank looking thing w/ the copper hoses coming in/out of it)it just shudders when the thermostat clicks. 75% of the time the ac breaker trips.Everything looks clean also. I so hate to call the "Man" to come fix it.
Old 06-14-2009, 09:21 PM   #4
HookMeUp's Avatar
Check the capacitor, it may have gone bad. It is used when starting the compressor.
2010 Wildcat 30LOFT
2011 RAM 3500 CCLB Cummins
HookMeUp is offline   Reply With Quote
Old 06-14-2009, 09:55 PM   #5
Cyber Phrenologist
Radio's Avatar
If you are lucky the starting capacitor is bad. Not too expensive and it's a DIY project. Also...quit trying to start the compressor...if the capacitor is bad this will only damage the compressor.
Hope you're lucky!
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is online now   Reply With Quote
Old 06-15-2009, 05:00 AM   #6
If it is a Dometic a/c unit, they are known to fail under a voltage drop and as stated above it just might be the capacitor. We had one fail at work and took out the control board as well and it damage the entire electrical system. To repair it was not worth it, it was more economical to replace it. The cost to replace the unit was $750.00 that's for a 13,500 BTU unit. My I suggest that if it comes to replacement have a Carrier installed and up grade to a 15,000 BTU, the cost is minimal. The next suggestion is, if you have the extra money have a Heat pump installed, this will give you a second source of heat with out using propane.
Old 06-15-2009, 11:57 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
It sounds like a start capacitor failure. Here's a link on how to test the capacitor to be sure.
http://www.wikihow.com/Check-a-Start-Capacitor
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-18-2009, 01:36 PM   #8
FYI, I just replaced the start capacitor in one of our Dometic low profile units that are on our parking booths. The first pic shows a good capacitor, the dark one is the start capacitor for the compressor. If you look at the next two pic you will see what has happen to the capacitor. We had a power bump and we end up having to repair or replace the unit depending on damage. This one was lucky, we had spare parts from another unit.
ID:	1619   Click image for larger version
ID:	1620   Click image for larger version
Old 06-20-2009, 11:33 PM   #9
I am going to put the new capacitor in tomorrow. The guy at the rv place said my first one had a bad connection on the inside,first one he ever saw like that.Hope it works. I also have been wondering if it could have something to do with the power converter
Old 06-22-2009, 07:40 PM   #10
Thumbs down Ac update
[B]Put the new capacitor in and it does the same thing, compressor wont kick in,breaker trips.I cant believe I will have to get a new ac on a 2005 surveyor.We also have a 1986 Gulfstream Conquest rv and that ac will run your ***** out and it is 20 years old!!!!!!!!!!Just goes to show they dont make em like they used to
