Holding tanks lower capacity than stated
I purchased a 2012 Palomino Puma 30DBSS in October of last year. According to all literature at the time and current lit, black and grey tanks are supposed to be 42 gallons each. This was a major consideration as our last camper had 25 gallon tanks and the grey filled up much too quickly. We've been on a few trips now and our grey tank seemed to fill up just as fast, and when reading full it could be held in a 25 gallon tote. My hope was that the indicator was not reading correctly and there was considerable capacity left when reading full. Unfortunately, this was not the case. Yesterday, using a 5 gallon bucket and with tank empty- after bucket number 6 (30 gallons) there was several gallons standing in the tub, indicating most likely a 25 gallon tank. Trailer is level. In my opinion, if specifications are changed and different size tanks are used, a purchaser should be made aware of that. It's one thing to be ABLE to make changes and deviate from published literature, but it's another to withhold that information from a customer. I have contacted my dealer about this issue- but what do you do? It would be a nightmare to change it out I would think- yet we are missing 17 gallons of capacity that influenced my decision heavily. It's not like confirming tank capacity is something that can be done during inspection before buying- you pretty much have to assume the published specs are correct or hope that a manufacturer/dealer are honest enough to inform you that the specs are not correct. Hopefully a reasonable response is forthcoming. Any advice or opinions?
