Old 07-15-2011, 01:23 PM   #1
greti's Avatar
Hooking up to electricity at home
Is it okay to hook my trailer to my home electricity with a heavy duty extension cord, like the kind used for the outdoors? I just want to get my refrigerator cold and that would be about the only thing I would be running?
Tennessee
2014 Rockwood Mini Lite 2504s
2006 Ford Expedition
greti is offline   Reply With Quote
Old 07-15-2011, 01:34 PM   #2
Coops1's Avatar
Absolutely, perfectly safe to do and very convenient.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-15-2011, 01:43 PM   #3
UpNorthMgoBlue
dlzeller's Avatar
I keep mine hooked up all the time while not being in use. That way if I want to escape the house for a cold beer, it's ready...LOL
dlzeller is offline   Reply With Quote
Old 07-15-2011, 01:53 PM   #4
grhodes50's Avatar
I recently installed an electric box at the house. It is the same as what you find at campgrounds with 50 amp, 30 amp and 20 amp service. I now can safely run anything I need or want, including the AC.
You might check into doing the same. It's worth it!
Old 07-15-2011, 02:07 PM   #5
frankm's Avatar
You will need something like this Amazon.com: Camco 55165 RV 12" PowerGrip Dogbone Electrical Adapter with Handle: Automotive then you will be all set.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 07-15-2011, 03:14 PM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Hey Gary, you've got a great set-up there. Actually nicer then some campgrounds we've stayed at.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-15-2011, 05:09 PM   #7
grhodes50's Avatar
Thanks Charlie. It's came in handy a time or two already.
Last weekend we set up the pup for our visiting grand daughters. We had to run the AC since the temps were reaching the mid 100's during the late afternoon. We wouldn't have been able to do that just plugged into 20 amp at the house.
We also are currently running the AC on the tt. Cleaning and loading the tt, getting things ready for the FROG rally next Wednesday.
Old 07-16-2011, 12:02 PM   #8
Retired US Navy Diver
Tennessee
2011 Rockwood Mini Lite ETC 185
Mitsubishi Endeavor
I would address you by your name but you don't post it. I plugged my TT into a wall outlet in my garage and smoked the extension cord and popped the breaker. (Revealing my ignorance to the quick criticism of some posters, HAAAA!!) All I wanted was power to keep the battery charged and the refer cold. Once I turned off all the non-essentials at the TT breaker panel I was OK. I have talked to a neighbor who is a retired machinist and does wiring/electrical projects on the side, about wiring my garage with a 50 amp connection. So it's in the works. You can also go online and there is a website that gives a detailed, w/ pictures, description of wiring a 30 or 50 amp connection.
My TT is 30 amp and thats the way I was going to wire but then the light went on and I realized why run 30 when you may as well run 50. Then if you ever upgrade or buy a new RV w/ 50 amp you'll already be set. For the 30 you just get one of the power adapters for 30 amp TT to plug into a 50 amp connection.
gktsuda1956 is offline   Reply With Quote
Old 07-16-2011, 12:06 PM   #9
OOps I didn't post my name, sorry.
Here's the link for 30/50 amp wiring.
RV Electric
Glenn
Longview, WA
Old 07-17-2011, 04:09 PM   #10
greti's Avatar
Question
Thanks to all that replied. To Glenn did you ever figure out why your extension cord and breaker were affected?
Tennessee
Old 07-17-2011, 09:07 PM   #11
dirttracker18's Avatar
Glen
You need to find out why that hapened. There is no reason for what that to happen. Without turning on the A/C you should easily be able to run on a 15 amp circuit with an extension cord ( a good one). We have done it many times and it is all I run on at our family cottage with a 100 foot extension cord. We can even run the A/C on low as long as everything else is off.
On the other hand when I built my new garage I put a 30 amp RV plug outside (for use by us or any visitors with an RV) and one inside in case I need to make repairs or have a service person come by.
It is an easy upgrade at your home and relatively inexpensive as you do not need outdoor or underground wire so long as it runs from your panel directly into a sealed outdoor box.
Doug
dirttracker18 is offline   Reply With Quote
Old 07-17-2011, 09:29 PM   #12
10Isola
Sorry for jumping in on the conversation, but what's the best way to hook in to home electricity with my 50amp cable from my motorhome? Would I just use my 30amp adapter with a 30-15amp dog bone?
10Isola is offline   Reply With Quote
Old 07-17-2011, 09:37 PM   #13
Coops1's Avatar
They make pig tails to suit the 50 30A services. These are a good idea and cheaper to replace than the rest of your gear if someone walks off with it.
26WRB - V-Lite
Denali HD LML
Old 07-17-2011, 09:46 PM   #14
Steve38's Avatar
try one of these.
Amazon.com: Dual 15 - 30 AMP RV adapter for Honda, Yamaha, & Kipor generator - convert two 15/20 AMP outlets to one RV 30 AMP outlet: Automotive
Steve38 is offline   Reply With Quote
