Old 12-31-2015, 11:14 AM   #21
DougP47's Avatar
If you don't need it right away.Check online to get the part. I found out the expensive way. Just buy the reset part and replace it for a few bucks instead of big $$. There's a part # on the old one use that for search.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 12-31-2015, 11:29 AM   #22
wmtire's Avatar
Also if you will notice, there is a thin strip that goes between the two terminals, per thermostat/ECO. This acts as a fuse, and burns up to protect the wiring from burning up as it cut's the power. You will notice in the pic above that the 120 volt AC t'stat/eco switch (the left one) has this fusible link burned up.
You may can check that part also for your 12 volt DC t'stat/eco.
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
hot water, water heater, water, heater
