The switch for operating in electric mode is accessible from the outside and is in the lower left corner of the heater (see photo). The two reset buttons are over temp resets and if tripped they will click when you push them. The switch for propane operation is inside. If the unit tries to start on propane several times the control board will put it in safe mode and prevent further lighting until reset by removing power.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
