Old 10-16-2015, 04:02 AM   #11
arpipeliner's Avatar
Have read on the forum about have having the outdoor shower turn on but the no water coming out depending on the attachment. They say the hot water can mix with the cold water. Others can explain better than I can.
arpipeliner is offline   Reply With Quote
Old 10-16-2015, 06:35 AM   #12
Just wanted to respond to let everyone know that the issue was not having ALL bypass knobs turned. Thank you for the pic of what it should look like. YAY!! We have hot water!
whisperwhillow is offline   Reply With Quote
Old 10-16-2015, 06:52 AM   #13
Head Rambler
I'd like to thank you very much for coming back and letting us know that you go it fixed and what the fix was. So many times people will come asking for help and when they get it working, they never come back and let us know how it turned out.
So a great big thanks.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 10-16-2015, 07:00 AM   #14
wmtire's Avatar
Good deal, glad it's all working now.
Even though your hubbie is in the Army, you may need to take Navy showers. With a limited 6 gallon water heater, you won't be able to shower for long times like in a house with a 30 gallon or larger water heater.
The Navy style shower usually requires you to turn the water on and adjust to your liking, and initially spray off (wet yourself and hair down). Then turn the water off with the control on the shower wand itself. Soap up and shampoo your hair. Now turn the wand back on and rinse off. Then turn off all the water at the taps.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-16-2015, 12:01 PM   #15
Also check your outside shower. Make sure both knobs are turned off. If not cold will get into the hot water.
Harkerr is offline   Reply With Quote
Old 10-16-2015, 01:02 PM   #16
HWH
Looks like you have all the proper information above for you to solve your problem. If you use the electric switch (as shown on the photo of the outside of your heater) you shouldn't ever have to use any propane. It goes FAST using that method.
I am sure the problem is the bypass valves.
Where are you located? If you are at the Fam Camp on any base, I am sure there would be a kind retired military camper who would help you. Their wives spent a lot of time waiting for their warrior to come home, and would jump at the chance to make life a little easier for a young warrior's wife.
If you are at Randolph AFB, or Ft Sam, let me know, and my wife and i will come by.
Hope you have this solved by now.
PS: If you are in really cold country, look into what you have to do to preserve heat. Some pipelines (people who work the pipeline projects) spend long times in their 5th wheels. and use straw bales around the bottom of the RV to keep things unfrozen. Works great. Others buy rigid insulation (an expensive project for a young soldier). For sure I use pipe insulation (soft stuff) and a heat tape on all my hoses, and insulate the stand pipe (the water pipe) where it comes in from the ground, and apply a heat tape there too.
hankpac is offline   Reply With Quote
Old 10-16-2015, 01:14 PM   #17
wmtire's Avatar
Uhh guys, she got it all fixed up and let us know in post #12.
Old 10-16-2015, 10:40 PM   #18
Haha, wmtire, I remember "Navy showers" all too well. Thank you for the heads-up.
Hmm, heat tape, huh? We're in Colorado right now and just a couple of days ago I was looking at the sewer hoses thinking of the mess if they were to freeze.
Old 10-16-2015, 10:52 PM   #19
asquared's Avatar
there are a ton of ideas on here on how to camp in the winter. First things first, realize that as it gets cold in Colorado, you will go through a good bit of propane. Depending on how the park you are staying at runs electricity, you may want to get a portable space heater to help. You will want to insulate your pipes, including sewer. Remember also not to keep the black tank open but instead empty it when its 2/3 or more full. Always keep at least a couple gallons in the black tank. You may want to look at the geo method for black tank management. Remember there is always help here on the forums. Thank your husband for his service and thank you for letting him serve. I grew up an Army brat so I know how hard it is to let them go do their calling and how special it is to be their family. Remember just as there are support groups through the base if you need them, This forum can be a great support group too.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-18-2015, 10:15 AM   #20
Thank you, asquared, for the added info!
heater, hot water, water, water heater
