10-21-2015, 08:30 AM
#21
Get yourself the shower head everyone uses and your showers will last 2-3 times longer, it really does work. My 6 year old showers and plays with toys for 15-20 mins at a time before hot water runs out. Is it Oxygenics shower head??? Can someone confirm?
I purchased mine about two years ago, best mod ever.
10-21-2015, 09:19 AM
#22
Bad Info! Members replace their shower heads to use LESS WATER not LONGER Showers! It is best to Practice water saving methods so when you DONT have FHU sites! Youroo!!
10-21-2015, 09:34 AM
#23
youroo, I 'think' Kuba was trying to say if you get the shower head people have raved about (his reference to the Oxygenics water saver) that your showers could last 2-3 times longer before running out of hot water.(or FW) At least that's how I read it.
10-21-2015, 10:44 AM
#24
Thats what i meant
10-21-2015, 10:46 AM
#25
Youroo, but, im seasonal and i replaced mine for the reason of LONGER showers. I dont like army showers. Chill dude
10-21-2015, 10:51 AM
#26
Hmmmm I'm not sure you use less water by switching to the oxegenics shower enabling you to take longer showers...........
Anybody ever check this?
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
10-21-2015, 10:57 AM
#27
Oxygenics specs say 1.6 GPM for the shower head at 40 PSI.
I have no idea what Kuba's original shower head flowed.
10-21-2015, 11:05 AM
#28
Easy to do, just use the outside "factory" shower head forest river uses for all there showers.
Maybe I'll check tonight.
I bet it's the same or even less.
Probably not even a worthwhile difference. Nonetheless I'll check.
TURBS
2008 duramax
2015 columbus 320RS
10-21-2015, 11:22 AM
#29
5picker: i had a stock showerhead, same one inside and out.
10-21-2015, 11:32 AM
#30
If people take LONGER showers they use MORE water,I'll stand by my Post #22! PS you may know DUDES but I am NOT one! Youroo!!
10-21-2015, 11:40 AM
#31
Not necessarily...
If your shower head flows 2.0 GPM (at 40 psi)and you take a 5 minute shower you've used 10 gallons of water.
If your shower head flows 1.5 GPM (at 40 psi) you can take a 6.66 minute shower and still only use 10 gallons of water.
That is a longer shower without using more water where I came from.
10-21-2015, 12:14 PM
#32
Is like a garden hose, you put your thumb on outlet and it will give you more pressure, but less water flow.
10-21-2015, 12:24 PM
#33
How high is up and how far is down?
10-21-2015, 12:32 PM
#34
Always Learning
And- how does this help the OP?
10-24-2015, 09:31 AM
#35
First thank your husband from all of us for his service this to country and you can not get more helpful people than the ones who are on this site.
2015 Forest River 21 DS
1999 F350 super 7.2 diesel
Showing basenjis
10-29-2015, 01:39 AM
#36
Thank you, almasibasenji. I'll let him know.
And I agree!
11-13-2015, 09:17 AM
#37
TURBS
2008 duramax
2015 columbus 320RS
Yes Glenn J and I! Test results,Oxegenics used MORE water! Youroo!! See Results at (VA Campgrounds,Post#5,11/3/2015!
11-13-2015, 10:00 AM
#38
Yes Glenn J and I! Test results,Oxegenics used MORE water! [emoji106] Youroo!! See Results at (VA Campgrounds,Post#5,11/3/2015!
Huh, so switching to an oxegenics shower head actually will allow you to use more water?
11-13-2015, 10:06 AM
#39
Evidently you need Ms. Amy to read the post and explain it to you.
11-13-2015, 10:10 AM
#40
[emoji651] [emoji651] [emoji651] [emoji651] [emoji651]
