Old 04-24-2016, 09:54 AM   #1
Hot water tank
Just noticed last nite the pressure valve dripping. Reason for concern?? What might cause this?? Tks!!!
Cardinal camper is offline   Reply With Quote
Old 04-24-2016, 10:00 AM   #2
Flybob's Avatar
Open it, let a little water out and let it close again quickly. Some times it can get some crud in it or just not seat properly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-24-2016, 10:01 AM   #3
bubbles's Avatar
Sometimes it's because when the release toggle is not allowed to snap back into position after opening after pressurizing the system it might leak a little. Also, some leakage from the valve could be normal as stated in the owners manual I have.
Old 04-24-2016, 10:02 AM   #4
Tks!!
Old 04-24-2016, 10:02 AM   #5
Only do this when Water is COLD! Youroo!!
Old 04-24-2016, 10:03 AM   #6
Tks for your help!!
Old 04-24-2016, 10:05 AM   #7
Ford Idaho's Avatar
Had this issue last year while at Crater Lake, Flybob is correct.
It took 4 quick flips to get it to stop leaking, I used a hand towel to keep the hot water from going every place.
Do be very careful.
Now you tell me.....
Old 04-24-2016, 10:07 AM   #8
Tks!! Will definitely try this!!
hot water, tank, water, water tank
