Old 06-23-2013, 12:45 PM   #1
How do I locate wall studs and ceiling trusses on my XLR Thunderbolt 300X12?
I received a wall storage system for the garage of my new toy hauler. There were no instruction how to install this. How do I locate the wall studs, and whats the best method for attaching this system to the wall? Screws?
I also want to attach a tv bracket to the ceiling in the garage, for a TV that weights 13 lbs. How do I locate the ceiling truss?
Thanks for the advise.
Pfenning
Pfenning is offline   Reply With Quote
Old 06-24-2013, 07:40 AM   #2
VinceU's Avatar
Haven't used on RV but household stud finders reportedly do work with wood/alum/steel studs. Additionally you can often sight the stiffs outside as a very slight rise in the side or roof skin.
Old 06-24-2013, 07:46 AM   #3
Phat Phrog
RVChick's Avatar
Pfenning
I am looking for a wall storage system too....where did u find one? A local FR dealer near me said FR might sell them.
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 06-24-2013, 09:09 AM   #4
MotocrossCamper's Avatar
I higher end stud finder may find them but I wouldn't count on it. If the walls were built properly a stud finder can't pick out the stud with the foam being tight up against it.
When adding a tv bracket to our Sunseeker I tried every trick in the book that I have learned from 20 years of construction and still couldn't find them. I marked out a section where the tv was going and uses a very small finish nail and had to keep tapping it through the wall until I hit metal.
MotocrossCamper is offline   Reply With Quote
Old 06-24-2013, 09:50 AM   #5
daydreaming about camping
jeeplj8's Avatar
I was told by the Coachmen factory that a stud finder would not be a reliable way to find a stud in our trailer. They actually suggest knocking on the wall and using sound to locate.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
