06-27-2011, 07:16 AM
#21
Originally Posted by cowpaddy
I only have access to 3 of 4 zerks. One of them is blocked by the electric motor that runs the landing gear. Someone wasnt thinking when they mounted the motor....
I have found there is an epidemic of this going around these days.
Adding another one lower down is an option. Not one I personally would tackle as I would be too worried about drilling into the jack screw.
Since you will only lube the gear once a year, I would remove the motor lube the Zerk, and put the motor back on as part of my pre-season duties.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-27-2011, 07:20 AM
#22
Originally Posted by snjparham
So I greased the front landing gear and I still have a rubbing sound when the landing gear is raised/lowered. It is not constant, but annoying. Are there other suggestions other than just the Zerk fittings for quieting/lubing the front landing gear.
You may have a slightly bent jack screw. I bent mine (a little) when I was a little low on a hook up attempt and pushed my camper off the front pads when it did not hitch.
I thought if I hit it one more time it would latch. (mistake) It should hook CLEAN, if not you are not aligned correctly so don't force it!.
If the jack screw still works (like mine does) get used to the sound (I have) or be prepared for a very expensive repair bill.
06-27-2011, 07:43 AM
#23
it made me look again. the only way i can see to get grease in mine is thru the top. the top caps come off.
what is inside the leg, a long all thread bolt? if that is the case, ur going to have to pump enough grease to make it down to the nut.
there is a cover on both sides that allows grease to be packed in. the one on the motor side is not easy.
a suggestion on the certs, if they are hard to get to, remove the cert and install a flexible grease tube (or pipe it) so that u can get to it.
the motor and gear box look like they are sealed.
06-27-2011, 07:52 AM
#24
you may try putting the tube of the spray grease in one of the holes in the leg and see if u can spray it up to the active component. (the height adjustment holes).
06-28-2011, 08:35 PM
#25
Nigel, I had the rig at the dealers to get the ladder installed, no fittings to lube the front jacks, and they dont put the fittings on new rigs, but no can tell me why or how to lube them, we even looked at a new 2012 with the same floor plan and nope not one on it, but again no can explain to me why or how to. I don't have caps to take off to lube them. I'm at a loss now.
Michael
The Family Truckster Team:
Michael & Belinda
06-28-2011, 08:54 PM
#26
Thanks Herk, I ended up pulling the right side bolt out of the shaft, this allowed me to slide the motor to the right and then twist up. Just enough room to get the grease gun on it. Greased the he'll out it so hopefully I won't have to do it again until next year.
Rockwood 8281SS
2007 F250 Lariat Crew Cab
One wife, two boys, two dogs
06-29-2011, 10:29 AM
#27
Michael
Michael thanks, do you know what make yours are, maybe I can contact the manufacturer to ask the question?
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
06-29-2011, 08:07 PM
#28
Great thread. Just looked and I have fittings, would have even never checked without reading this thread. How much grease should I put in?
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
06-29-2011, 08:14 PM
#29
Mine are flat on top no grease zerks but looking closer there is a hole about 1\2 inch from top you put a small screwdriver in hole push slightly and the hidden cap pops up and you can see the gears an a small dab of grease I can put more on now that I found the cap.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
06-29-2011, 11:25 PM
#30
I put a few pumps when I do my annual overhaul. Then I run the landing gear through its full travel to distribute it. A wipe down of the legs and you are done.
07-11-2011, 09:57 PM
#31
For all the guys with no zerks!
This thing has been bothering me! I bought new specs, (seriously) and I found on top of my towers two flat, thin, metal plates that pry off with a knife blade, switching on the light also helped. I could feel a gear in there so I packed in more grease. Not sure yet how to lube lower down, I will post what I find.
Nigel & Bev
07-11-2011, 11:40 PM
#32
This stirred me into going out to check my landing gear. 2011 Rockwood Signature 8244S. I found a grease zerk at the top of each leg facing the front. Without this thread they would have gone forever un-greased! As for the one near the motor, the zerk is located just below it.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
07-12-2011, 06:31 AM
#33
Here are some pictures of my gear tops.
07-13-2011, 05:08 PM
#34
Herk, mine look like that but I don't have zerts just the holes are there. Did you add yours to preexisting holes or you drilled yours then put them?
07-13-2011, 06:04 PM
#35
What you see is how it came from the factory.
I would check to see it the holes are threaded. Bend a paperclip into a "hook" and strum it through the hole. If it vibrates it is threaded.
You can buy Zerks at any auto store and screw them in yourself if the holes are tapped.
