Old 07-07-2008, 06:25 PM   #1
How do I remove this reading light?
Hi all,
My wife and I own a Rockwood 2605. One of our reading lights over the bed is flickering:
It's probably something simple like a loose wirenut. Although it's under warranty, the closest dealer is over an hour drive so I'd rather try to fix it myself. How do you remove these fixtures? I gently tried twisting it both directions and it didn't go anywhere. Before I go completely breaking this thing trying to fix it (I tend to do that), I figured I'd check here - how are these fixtures removed for repair/replacement?
Thanks!
- Chris
chrispitude is offline   Reply With Quote
Old 07-07-2008, 07:42 PM   #2
Flickering Light
I replaced the reading lamps in my first Rockwood. They were removed by rotating the fixture counterclockwise, firmly.
I sure hope you don't have different kind and cuss me when it disintegrates in your hands!
TacBear
TacBear is offline   Reply With Quote
Old 07-08-2008, 11:01 AM   #3
Hi TacBear,
That worked perfectly and I obtained access to the wiring! Thanks a bunch. Once it gets dark outside, I'll see if I can make the flickering lessen/go away if I tighten the crimp splices a bit more.
- Chris
