Old 04-25-2015, 06:51 PM   #1
how do i start the furnace in a 2015 wildwood 26tbss?
I am getting ready for the season and everything seems to work but I have never used the furnace before. How do I start it? Thanks
nealmcgovern is offline   Reply With Quote
Old 04-25-2015, 06:52 PM   #2
fonzie's Avatar
Make sure propane is on, thermostat on heat and then set temperature...it should start if all OK.....
Fonzie
Old 04-25-2015, 06:53 PM   #3
I have tried that, but I didm;t even hear the blower motor start
Old 04-25-2015, 06:56 PM   #4
I checked all of my fuses and they are nor blown. I checked the propane system is working by lighting the stove burners. I set the thermostat to the furnace setting and turned the temp way up but nothing seems to happen at all
Old 04-25-2015, 06:59 PM   #5
fonzie's Avatar
For the fuses, did you actually check visually by pulling fuse out and looking at element to see if burn for the furnace? don't rely on the red LED......this is first step. What kind of thermostat you have? Are your 12 volts light working?
Fonzie
Old 04-25-2015, 07:03 PM   #6
Cyber Phrenologist
Radio's Avatar
My furnace has a rocker switch on the side of the furnace itself that must be turned on before the furnace will operate. From inside the trailer it is on the right hand side, in the middle, in a little square hole.
You'll have to feel around for it.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 04-25-2015, 07:05 PM   #7
Hi Fonzie. I did remove and inspect all of the fuses. I don't like relying on LED's either. I was thinking there is a step in the procedure that I am not doing properly. My battery is charged and I have it plugged into house power, so power shouldn't be an issue. Lots of propane in the tanks. I did notice on the power panel in the trailer that the cooling fan does not run for very long, isn't it supposed to always be running?
Old 04-25-2015, 07:06 PM   #8
I will look for the switch
Old 04-25-2015, 07:09 PM   #9
fonzie's Avatar
The fan on the converter will only run when needed, depends on the loading eg: how many ligths are on, if furnace running etc etc
Fonzie
Old 04-26-2015, 05:41 AM   #10
Hi guys. I found the switch that Radio mentioned after I removed some interior panels. The switch was in the ON position. When I was looking at the wiring , I found a small white wire paired with a red wire. The red wire is crimped with a larger blue wire, the white is not crimped to any other wires. I also saw another blue wire with a crimp on the end but no other wire. I think the white wire has broken off at this crimp, it's a 20-22 gauge wire so it could break easily. I think this is why the furnace won't start. I will have to call the dealer though before randomly connecting wires on a propane furnace. Thanks for the help, ill post the result after the dealer checks it out.
26tbss, furnace, wildwood
