Old 05-11-2013, 10:15 AM   #1
How do you find level?
I know how to use a level, but when trying to level our new trailer so that the fridge is level we discovered that nothi g is perfectly flat. The floor gives different readings depending on where you put the level. The counters are clearly not level. The floor of the fridge is lumpy. The bottom of the freezer is the flattest thing we could find.
What does the wisdom of the forum say is the best way to determine level? (After we get it level once we will out the stick on levels in place.). Thanks!
cobrageek is offline   Reply With Quote
Old 05-11-2013, 10:24 AM   #2
tmmar's Avatar
Many years ago I was told that you should go by the floor of the freezer. I got a small target level (a round level a little bigger than a quarter) and put it in the center of the freezer floor. Once I leveled the coach to that, I put stick on levels on the cabinet above the refrigerator- one facing front and one facing toward the side so I can easily check to make sure I am level. I have been doing it that way for 30 years without any problems.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-11-2013, 10:26 AM   #3
Rugged Brown's Avatar
I gave up on level.. Every level I buy at the hardware store leaks and ends up with a little bubble in it. I just guess now.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-11-2013, 10:34 AM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
My old freezer had a spot that says level here. Now, I take an average over a few places. 1/2 a bubble is close enough for government work.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-11-2013, 10:56 AM   #5
Freezer floor it is. That does seem to be the flattest place we could find. We setup using an average of spots on the floor this time so the freezer floor is slightly off from that. I'm sure it's fine, but I don't want to put on our stick ons until it is more level. Thanks for the advice. The forum wisdom is always great.
RB, all my levels seem to have bubbles as well so I think there must be something wrong at the factory. :-)
Old 05-11-2013, 11:06 AM   #6
I have both a 12 inch torpedo level and a little round disc level. I start with the tongue when leveling. When done, I check the counter next to the door, and confirmed that I didn't twist the camper when dropping the stabs, and then check the freezer floor. All 3 of those spots are pretty close on my unit when it is level.
Locomotive Engineer
Old 05-11-2013, 11:06 AM   #7
Himcules's Avatar
why would the floor of the freezer be the reference gauge for level?
doesn't make sense to me. the fridge/freezer is an appliance that gets installed into a cabinet. it is leveled and plumbed off the cabinet.
the cabinet/woodwork is installed on the floor and wall of the coach. that cabinet is leveled and plumbed off the floor.
so all reference points goes back to the floor of the coach.
for level, i use a big clear water pitcher. i either put that on the countertop or the floor and level the coach according to the water line. once the water line is leveled, i'm level. water will always find level. gotta love science to keep it simple.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-11-2013, 11:08 AM   #8
The refrigerator is the main thing you want level. If it is not as close to level as possible (for me less than 1/2 bubble) then you could have issues with the refrigerants crystallizing.
Locomotive Engineer
Old 05-11-2013, 11:21 AM   #9
Himcules's Avatar
ok, so it's normally accepted that the fridge is not installed plumb and level to the floor of the coach?
way off level will affect the ammonia levels pooling in the coils and tubing of the fridge. gravity flow of the ammonia fluid into the burn chamber will be slowed down if adversely leveled. otherwise, the system will work just fine.
just like draining of the shower, sinks, toilets. if those aren't level they have issues as well. the greater off level, the greater the issue. all those other systems are installed leveled to the floor of the coach.
using the floor of the freezer as the reference still doesn't make sense to me. besides wastefully leaving the door open during the leveling process, you either need a helper to tell you where it's at or you run back and forth to check a bubble level that fits in the fridge. the smaller the gauge, the less accurate it is. the larger the leveling gauge, the more accurate it will be for the overall coach (it's systems).
this practice makes no sense to me.
Old 05-11-2013, 11:29 AM   #10
tmmar's Avatar
Him,
I leveled my coach when the refrigerator was off before I took it out for the first time. I them put 2 small levels one on each side of the corner of the cabinet over the fridge. That way, my wife can tell at a glance if we are level. Makes it a lot easier than going the pitcher route.
Tom and Margaret
Old 05-11-2013, 03:41 PM   #11
Himcules's Avatar
Originally Posted by tmmar View Post
Him,
if i understand correctly, your 2 small levels are on the corner of the door of the fridge? (since the body of the fridge should be inside the cabinet, at least on the coaches i have experience with). if so, the door is on hinges and are adjustable and may shift around. further the seal around the frame to the door is that magnetic compression seal that moves. so true squareness, level and plumb cannot be referenced from the fridge door.
i still find no scientific reason why the fridge is the reference point to measure level from.
the pitcher of water is just a tool. just like your small leveling gauges. as long as you have a tool, then you can reference level as best the tool can measure.
however, if the method works for you and you feel good with it, by all means go with it...
Old 05-11-2013, 03:51 PM   #12
KyDan's Avatar
I used a 4 foot carpenters level to level the frame front to back and side
to side. I used a floor jack to raise one side until level. I used the tongue
jack to get level front to back.
I stuck on 2 tiny bubble levels on the right front corner. I now use those
to judge blocks under a tire if necessary and to set tongue jack.
This was 4 years ago.
Haven't checked with the big level since then.
Fridge works, I'm happy. YMMV
Peace!
Dan & Rita D
Old 05-11-2013, 03:55 PM   #13
A general rule of thumb used with the newer models is "if it is comfortable walking in the camper, it is good for the refrigerator"
Our refrig. in in the rear wall, so if I am level side to side according to the big level on the pinbox. I'm good to go. I set the pinbox level by leveling off the bottom side trim molding and the rear trim molding which is close enough for me.
Old 05-11-2013, 04:04 PM   #14
acadianbob's Avatar
Originally Posted by OldCoot View Post
A general rule of thumb used with the newer models is "if it is comfortable walking in the camper, it is good for the refrigerator.
X2! I don't think one needs to obsess about it. I just put a torpedo level on the floor by the outside door; level side-to-side; and then front to back. That's been working on the same trailer for 6 years now without any issues.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 05-11-2013, 04:20 PM   #15
prof_fate's Avatar
Too far off level just feels weird to me when I"m at the table or laying down.
I dont' aim for perfectly level - not likely to get it anyway as I dont' bring boards/lego blocks in 1/8" incrememnts - so 1" side to side is the best I'm likely to get.
When I first got the TT I leveled in the driveway and put on levels..which fell off or didn't work well, so I put on anohter type and had similar issues. I gave up on that.
My ipod has an app for level - put it inside the door and have a child watch it. I also have a 2' level for reference and place that across the TT tounge.
As to the floor being level - well, it's attached to the frame...so why not start there?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-11-2013, 04:25 PM   #16
B47
Same here - I place a 4 foot carpenters level on the FW entry door sill for front to back level and on a stair tread for side to side level.
We never had to make large adjustments with the stabilizers to get level,but we also have only parked the FW at CG's that have concrete pads.
Works for us.
Old 05-11-2013, 04:48 PM   #17
It's not just the fridge to try and keep level. If you have a tub/shower, the water can run onto the floor if not level.
I figure the straightest reference point is the frame for front to rear level and the bumper for side to side. I just added a T-level to the tongue to make it easier setting up.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-12-2013, 06:17 AM   #18
We have a Sunseeker, which is a Class C. I use a small plastic level that has two tubes at 90 degrees. I place it on the coach's (linoleum) floor while sitting in the drivers's seat. I will sometimes move the coach back or forth to find a better starting point. The reading varies a lot depending on where I put it, but there is a spot within reach that seems to correlate well with the overall coach's level plane. As others have stated, the floor isn't prefectly flat and the countertops aren't perfectly parallel to the floor.
As a check, we see how the refrigerator door swings. If the coach is nice and level, the door will stay where you leave it.
Old 05-12-2013, 06:36 AM   #19
MI Camperz
bodzcampers's Avatar
We use the two outside levels...one indicates side to side level and the other indicates front to back level. Once those appear level, we place a carpenters level on the floor (as close to the center of the camper as possible) and tweak it with that. We believe the carpenter's level is a tad more accurate.
MI Camperz
bodzcampers is offline   Reply With Quote
Old 05-12-2013, 06:41 AM   #20
We use this and get readings for front to back and side to side.
« Bearings | Mattress »
