Old 12-20-2010, 01:58 PM   #1
How do you remove the lens from the Patio Scare Lights?
Have a new Blue Ridge with what FR calls Patio Scare Lights on both sides of the 5er. My question is how do you remove the plastic/glass lens? I've looked at the fixture and don't see how to remove it, for bulb replacement. Help appricated.
bailer6334 is offline   Reply With Quote
Old 12-22-2010, 10:35 AM   #2
If you have the ones that are mounted on my 2006 Wildcat 29RLBS I think you'll find that the ring that holds the scare light in has six or eight screws that fasten it to the side of the RV. Remove the screws and carefully pry the ring up (it'll be held by the caulking the factory used to seal it). The lens should then come off and reveal the bulb.
Mike
04.5' Black Ram 2500 CTD, 6 speed, 4WD, 4.10 Diff., Jake Brake, Short Bed.
2006 Wildcat 29RLBS
mschrowang is offline   Reply With Quote
