09-27-2017, 04:11 PM
How does this stupid table go down?? Pic is on it's side. Thanks in advance
09-27-2017, 04:34 PM
Originally Posted by Sharon.72064
the yellow button/cap is on a hook like lever, unhook that lever(you will hear a click) and then either push or pull on that area and it will move, ....
09-27-2017, 04:41 PM
Fella10 is absolutely correct. I usually turn the table upside down first. Releasing the pressure on the frame makes it easier.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
09-28-2017, 08:41 AM
It's totally unintuitive. Stand at the latch end of the table, release the latch as described and pull the table TOWARDS you. Don't try to push it down - once it starts to swing towards you, it will begin to lower on its own. Just guide it down into place, where it will latch closed.
One of the reasons we leave ours up, even for travel.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
09-28-2017, 08:58 AM
Stand table upright on it's legs in the dinette with the yellow button towards you. ( If it's new spray a light shot of WD40 on all the pivot points to loosen it up and the spring loaded pin adjacent to the lever with the yellow button.) place your foot on the base leg, slide the lever and pull the table top towards you. It should start to collapse. As it does slide it into place on the bosses where it rests. Very simple once you've done it a couple times.
To raise, lift up the front end (only) allowing it to pivot on the two rear bosses attached to the seat. Move the yellow button and rotate the leg assembly downward into final position and release the latch. Pull the table forward rotating it up and onto it's legs
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
09-28-2017, 09:34 AM
Thanks to everybody who came to our rescue! Don't understand why they have to make a table so hard to use, and one that is so wobbly?
So thank you
09-28-2017, 11:44 AM
Kasual Kamper
Totally agree with the above. Short of replacing the thing entirely, what have people done to stabilize this thing? Tried taking the feet off to see if it would keep it from rocking, but the bolts on the bottom stick out.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
09-28-2017, 12:10 PM
So thank you
It's not just you............that table is a PITA. I have one in my Roo 23SS.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
09-28-2017, 12:12 PM
Originally Posted by JayArras
... what have people done to stabilize this thing? ...
the pic's show how I've secured it, ... plus how we use it to hold the power strip used for our laptops, ect, that we use on the table, .... post #8 in the link below will give more pic's and info of how we've modified and use this table, ... we love this table and how large it can be, we wouldn't want a smaller one, ....
http://www.forestriverforums.com/for...wn-144849.html
09-30-2017, 06:49 AM
We hold ours in place for travel with a strap, secured on one side with a screw and the other with a turn button.
The strap holds the table tight to the rail in travel and is easy to release during setup to make room for legs.
