Old 05-21-2013, 09:02 AM   #21
And Herk, if you look at the bracket that the rear jack assembly is bolted to, you would see that it is welded ON TOP of the frame flange. If they had welded it underneath, the load would just push under the main frame, a very strong configuration. But by welding it on top. the load is being carried by a few very poor welds.
Some days I just shake my head at the guys who run the assembly of these units.
My bet is that they do it that way just because it is easier to weld that way. Their welders probably aren't very good at welding upside down.
bakken is offline   Reply With Quote
Old 05-21-2013, 11:16 AM   #22
After looking them over pretty closely this am, I've decided to just let them go and if they collapse for some reason or other, I'll repair them and reinforce where necessary. The whole assy, IMO is pretty flimsy and too light even for just stabilizing. Sure glad we don't have kids jumping around.
Old 05-21-2013, 01:41 PM   #23
checca's Avatar
Lightbulb First attempt to fix....
Ok ... here is my first attempt with some wood blocks and a jack.
its about 90% there ... i need a large C clamp to bend the middle in alittle more.
and then do alittle welding.
ID:	31046   Click image for larger version
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 05-21-2013, 01:58 PM   #24
Herk7769's Avatar
The manual is pretty clear they are for "light stabilizing" only. Attempting to "jack up" the frame will result in failure.
HAM CALLSIGN - KC3FFW
Old 05-21-2013, 02:03 PM   #25
One of these days when I get energetic, I might just pull the whole unit down and see what can be done to change it over to a medium-heavy duty stabilizing unit.
Old 05-21-2013, 02:19 PM   #26
Checca, try either square tube or a pair of angle iron lengths bolted inside the leg. You may need to cut or drill a hole to allow for the existing bolt for the braces. I like 1/4" thickness for either the tube or angle. This should allow for some pounding into shape as well as reinforcement.
Timtation is offline   Reply With Quote
Old 05-21-2013, 02:23 PM   #27
checca's Avatar
great suggestion ... i will try that.
Minooka, IL.
Old 05-22-2013, 06:40 AM   #28
KyDan's Avatar
Home Debit (depot!) sells short lengths of angle iron.
Over priced but convenient.
KyDan is online now   Reply With Quote
Old 05-22-2013, 07:08 AM   #29
Originally Posted by KyDan View Post
Google BAL jacks and see what you get.
I just did. The type you have come in pairs for around $85.
Donno if you can get just one cheaper or not.
Try a local dealer for a single one.
They are a simple bolt on replacement so you can do this or a
friendly neighbor with a socket wrench can do it and save labor cost
as well as a trip to the dealer.
Good Luck!
OP shows (Lippert Elect.stabilizers) ,not Bal jacks? Are the Parts the same? Youroo!!
Old 05-22-2013, 07:30 AM   #30
KyDan's Avatar
Probably not! I didn't realize they were electric.
Mine are electric also-- I use a battery powered electric drill to operate them
Peace!
Dan & Rita D
Blue Ox WD hitch
