Old 03-03-2015, 12:50 PM   #1
How to clean flue
Is the flue also called the chimney for the fridge? How to clean it?
Rockwood2703 is offline   Reply With Quote
Old 03-03-2015, 12:52 PM   #2
TURBS's Avatar
You shouldn't need to.
TURBS
Old 03-03-2015, 12:59 PM   #3
Just got off the phone with a mechanic for the fridge. He suggested to clean that and also that maybe a work light to heat up the back of the fridge so the gel isn't froze. I didn't mention I'm up north with freezing temps for right now. I guess that model fridge suggest around 70 degrees to start up. Dosent make much sense to me if it seems to be an electrical problem. I'm just trying to cover all possibilities. The worker won't come out to troubleshoot until I try what he suggests. Something bout paying out of pocket.. Warranty will step in later after I pay
Old 03-03-2015, 01:08 PM   #4
geotex1's Avatar
I actually disagree with Turbs on this one. Sometimes you do need to give a cleaning to the fridge and the furnace, especially if you boon-dock primarily and run on propane often as we did with out HTT. Easy enough though, just a compressor and an nozzle.
geotex1 is offline   Reply With Quote
Old 03-03-2015, 01:20 PM   #5
TURBS's Avatar
Now wait one minute we're talking about two different things here.
No you should not have to clean the "chimney" up out the top of camper.
Yes you should clean the burner flue yearly.
TURBS
Old 03-05-2015, 09:32 AM   #6
Crockett's Avatar
maybe we need to back up to square one. whats the symptome?
Crockett is offline   Reply With Quote
