Old 08-02-2016, 10:46 AM   #11
Not totally sure what you're doing, but it seems way more complicated than it needs to be. Most of us remove the wires from the analog T-stat and move them to the digital t-stat. End of story. But maybe you've got one of those weird systems?
If old one has 2 fan speeds and new does not, add a SPDT switch to chose fan speed.
Here's what swapped for my Coleman-Mach to a Honeywell.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 08-02-2016, 11:18 AM   #12
Captain America's Avatar
This is for a Dometic AC unit. I know a Honeywell tstat will work on a Coleman, but don't know on a Dometic. I like the how the Dometic digital tstat automatically switches fan speed based on set temperature.
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 08-02-2016, 02:42 PM   #13
Dometic to digital Honeywell changeover can be done with just simple change out of the wall thermostats. No need to change anything on the AC unit.
Henboy is offline   Reply With Quote
Old 08-02-2016, 04:03 PM   #14
sfsgm's Avatar
For me, the icons appear in the first part of the thread but the photos come out as I scroll down.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 08-02-2016, 06:00 PM   #15
That's because he fixed it (added the pics properly). See post #9.
Old 08-02-2016, 06:16 PM   #16
Are the pics thoughout the post or all at the end? I meant to post a pic with a description. If the pics all show at the end with the icons throughout the post, let me know how to fix.
2011 Wildcat 32QBT
Old 08-02-2016, 07:18 PM   #17
IHDRIDER00's Avatar
2X Henboy. Seems much easier. I did that on my 2004 All American Sport. Just added a SPST switch to get Hi Fan. But Thanks for the info. Cap. looks like you did a great job.
IHDRIDER00 is offline   Reply With Quote
Old 08-02-2016, 10:18 PM   #18
Capt: There's a way to do it, but I don't know it.
Old 08-03-2016, 05:46 AM   #19
I recently changed my analog thermostat to Dometic's Digital Comfort Control Center (CCC). As you expalined, the change over was relatively easy, however, I did run into an operational problem. The wall cavity behind the thermostat is very warm compared to the cold air inside my motorhome - the end result is that moisture forms on the face plate and on the PC board. When this happens, there is a short, and the thermostat looses the communication link with the AC units. To solve this problem I sprayed some Window and Door Spray Foam into the cavity and placed a thin piece of sheet foam between the wall and the PC board. So far, it seams to have solved the problem.
veraken is offline   Reply With Quote
dometic, replacement, thermostat
