Old 08-02-2016, 09:41 AM   #1
Captain America's Avatar
HOW-TO: Dometic analog to digital thermostat replacement (pic heavy)
I recently did a Dometic analog to digital thermostat replacement and want to share the install. It was an easy install once I got the old control box out and organized the wires.
First, turn off the main breaker and the battery disconnect to cut all power to the AC unit. There is a 12 volt supply to the control box, so be sure to kill all 12 volt power.
The digital control box(right) is smaller in size than the analog box(left), but resides in the same brackets.
Analog
Digital
Cut the tstat wires, 12 volt wires, and heater wires. Unplug the AC control wire bundle, freeze sensor, and disconnect the 110 volt supply. Remove analog control box.
Remove the old freeze sensor and replace with new supplied sensor.
New(left) and Old(right)
Press new sensor into fins one inch from bottom (I put mine on the lower right looking toward rear of RV) and gentle bend fins around sensor to hold into place.
Connect the 110 volt supply to the digital box, matching wire colors and using wire nuts.
Find the two heater wires and attach the supplied spade terminals. The heater wire in this RV is a two wire cable consisting of a red and white wire.
Affix the digital box to the bracket on the AC unit with supplied screws.
Plug in the AC control wire bundle
Plug in the heater wires
Plug in freeze sensor.
Remove analog tstat
The digital tstat only uses three of the seven wires of the tstat cable. I choose red, white, and orange to match the color wire at the control box.
Connect the three wires.
Red: 12 volt positive +
White: 12 volt negative -
Orange: Common or communication
Before attaching tstat to the wall, be sure to cover hole is wall where the tstat cable protrudes. This will keep hot air for escaping wall cavity and give the tstat a false reading. I used some insulation and covered with foil tape.
More on next post.........
ID:	116089   Click image for larger version
ID:	116090   Click image for larger version
ID:	116091   Click image for larger version
ID:	116092   Click image for larger version
ID:	116095   Click image for larger version
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 08-02-2016, 09:45 AM   #2
Can't see your pics. Need to use "Go Advanced," and then "Manage Attachments."
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-02-2016, 09:51 AM   #3
At the control box there is a wire harness that consist of a orange, red, red/white, and black.
Orange wire harness to orange tstat wire.
Red harness wire to RV 12 volt positive (+) supply
Red/white harness wire to tstat red (+) wire
Black harness wire to RV 12 volt negative (-) supply AND white (-) tstat wire
Plug wire harness into the control module.
Looking from left to right...
110v supply...freeze sensor...tstat wire harness....heater wires
Wire tie wires into a bundle and zip tie.
Turn on the breaker and battery disconnect and test AC.
ID:	116101   Click image for larger version
ID:	116102   Click image for larger version
ID:	116103   Click image for larger version
ID:	116104   Click image for larger version
2011 Wildcat 32QBT
Old 08-02-2016, 09:54 AM   #4
Great....the pics show up on my side.
2011 Wildcat 32QBT
Old 08-02-2016, 09:56 AM   #5
All I see are small icons that won't open.
Old 08-02-2016, 09:57 AM   #6
All I can see are small icons that won't open.
Old 08-02-2016, 09:58 AM   #7
I'm in a iPhone and see no pictures.
Old 08-02-2016, 09:59 AM   #8
Hey Cap, they don't show up in the thread. go to edit, then to advanced, then down below the text box you will see "Additional Options" and "Manage Attachments". Upload your images using it. I have found that if you use the insert image box you need to provide a URL address, but when you copy the address from your online library, the address is an HTTPS and due to this will not show up.
Hope this helps.
ShermanD
ShermanD is offline   Reply With Quote
Old 08-02-2016, 10:11 AM   #9
I edited using manage attachments. Hopefully they show. I tried to post pics while giving a description under each pic.
Jack of all trades, Master on none. Including posting on a forum. Hahaha!
2011 Wildcat 32QBT
Old 08-02-2016, 10:22 AM   #10
W5CI's Avatar
I was wanting to upgrade to the digital thermostat but not any more if it is that complicated. I did the replacement for a Coleman, they have a direct replacement,wire for wire took maybe 15 minutes.
2004 Cedar Creek 30RLBS MORryde IS/Disc Brakes
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29 2016 Days Camping 50
2017 Days Camping 8
W5CI is offline   Reply With Quote
dometic, replacement, thermostat
