Old 06-22-2011, 06:36 PM   #1
Send a message via AIM to jk31668
How to find studs
in a 2010 sunseeker 3100ss i want to add/mount another fire extinguisher in the rear bedroom area. what's the best way to locate the studs to screw the bracket into? thanx
jk31668 is offline   Reply With Quote
Old 06-22-2011, 06:42 PM   #2
push on the wall...if it moves...move across...or buy a stud finder at lowes, home depot
bwssr is offline   Reply With Quote
Old 06-22-2011, 07:39 PM   #3
RubenZ's Avatar
Ya, I'd get a stud finder. They can tell you where center of stud is.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 06-22-2011, 08:39 PM   #4
RPAspey's Avatar
here's what I did..
I used a FLIR thermal camera to locate my studs. Yeh I know its $10k but it works!
Normally, I use the knock with a knuckle and listen for a solid surface method.
Oh, the faint white lines are the studs. the bright white corner is the water leak I was looking for.
RPAspey is offline   Reply With Quote
Old 06-22-2011, 10:14 PM   #5
Look for the row of staples holding the paneling on, or whatever the interior wall is. They will be driven in to the studs.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-22-2011, 10:37 PM   #6
49 year camping veteran
Maxterra's Avatar
I just replaced the anemic factory "extinguisher" with a 5 & 7 pounder by each door.
I appears there is about a 2" wide frame around the doors, suitable for attaching to (as was why the original extinguisher was mounted there).
I placed both extingusihers on the floor due to weight, and used the bracket just to hold in place.
Maxterra is offline   Reply With Quote
