Old 05-14-2016, 12:46 PM   #31
Canadian Full Timer
I noticed yesterday that a wasp had entered the end of our awning. We do not put the awning out any more and now that my husband has passed away, I doubt that I will be doing so in the future either as it is just too difficult for me to handle alone. However, if there is a nest inside already, can I use that foam spray stuff at the ends of the awning and just let "sleeping wasps lie" on the inside? Any suggestions would be helpful. I have considered removing the awning altogether but that is probably not a good thing to do if I wish to sell it in the future. Thanks!
Cherokeerose is offline   Reply With Quote
Old 05-14-2016, 01:06 PM   #32
Iwannacamp's Avatar
You can do as you will. Any insecticide will kill wasps. Soap will kill bees, but not wasps.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-15-2016, 12:20 PM   #33
Sc00ter's Avatar
Installed regular window screen on our fridge intake. Cut into strips and used a hot glue gun to stick to the back of the intake cover. Being an intake, the temps will never get hot and any flow restriction will be negated by the two large fans I installed to draw more air in. The little %]}>#>]^s have been circling the camper all spring looking for a place to build a nest. So far so good.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-17-2016, 08:32 PM   #34
Actually I kill wasps with soapy water as well. The first thing it does is coats there wings and they drop immediately. I trust it so much that I go under my 20x24 pool deck with a spray bottle a couple times each summer to spray red wasp, yellow jackets and anything else that flies and stings. Its awesome.
Grisham91402 is offline   Reply With Quote
Old 06-07-2016, 10:37 PM   #35
Wd40
2016 Grey Wolf 26DBH
2003 F150 4x4
gconley is offline   Reply With Quote
Old 06-08-2016, 05:55 AM   #36
cpaulsen's Avatar
I used regular insect screen on my furnace/water heater/and frig vent. Cut the screen to size and hot glued it to the inside of the vent. Have done that on my last 3 6vers and have never had a problem.
cpaulsen is offline   Reply With Quote
Old 06-08-2016, 09:21 AM   #37
These things work amazingly well.
We had a problem with wasps at our seasonal site last year and put a couple of these traps up. They work really well as once they fly in, they can't get back out. There are also directions online for making home-made ones with an empty 2-liter bottle.
As far as cleaning out nests, brake cleaner spray works great to kill them on contact. It also sprays out pretty far allowing you to stand a few feet away when you spray them.
Iwritecode is offline   Reply With Quote
