Old 11-22-2010, 08:11 AM   #1
Wanna Be Camper
SaskCampers's Avatar
HowTo Winterize an RV The Basics
Just thought I would pass on some tips for winterizing your RV. These are not gospel but intended to help out new RV'rs to get through their first winterizing and maybe refresh experienced Rv'rs memories.. It is a .pdf to make saving and printing easier..
Hope it helps at least one person get through the winterizing process a little easier..
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 11-22-2010, 08:48 PM   #2
great white's Avatar
Cool!
(or it that cold?)
great white is offline   Reply With Quote
Old 11-22-2010, 11:09 PM   #3
RV Newbie
buzzards27's Avatar
Sasks,
should the low point drains portion also tell you to open all of the faucets and to work the toilet while the drains are open? I don't think the water will drain too well if you don't open the faucets.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 11-23-2010, 05:25 AM   #4
Wanna Be Camper
Originally Posted by buzzards27 View Post
Sasks,
Mine drained fine with the faucets all closed.
John & Deb
Old 11-23-2010, 09:49 AM   #5
Infractee
Quick question, what kind of precautions need to be taken if you are camping (using CG water supply) and an overnight freeze is expected? My tanks are heated but as far as the water hose from the CG spigot to my city water connection, what neefs to be done? Fill fresh tank and disconnect CG water?
RhoZeta is offline   Reply With Quote
Old 11-23-2010, 10:25 AM   #6
I would do that to be safe.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 12-10-2010, 05:12 PM   #7
Send a message via Skype™ to scubieman
Question? What's better blowing out with air or running rv antifreeze through? The problem is I already hit a very cold days so if anything is to break it probably would have already
scubieman is offline   Reply With Quote
Old 12-11-2010, 08:21 AM   #8
KyDan's Avatar
That's like asking what's better, hotdogs or hamburgers.
They are different.
It's possible you can get by OK with just blowing out.
It's possible some water will gather in a low spot
and freeze after you do that.
Some folks get by year after year just blowing out.
We can't guess how much pressure or air volume you
can blow thru your system.
Pumping RV antifreeze entirely thru your system is
just about guaranteed to prevent freeze problems.
As far as damage you have already I'm not sure
what you are asking.
Around my house it's way late to be winterizing.
It had better be done by now!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 12-11-2010, 09:24 AM   #9
Wanna Be Camper
My dealer recommends the RV antifreeze as the #1 choice with blowing things out as #2. I can see that as the antifreeze also keeps seals, valves and your pump lubricated and wet so they won't stick in the spring. The way I see it, I paid over 30k for the trailer so if I cannot afford $10 or $12 for RV antifreeze well perhaps I shouldn't own the RV to start with.
John & Deb
