Old 12-10-2017, 12:11 PM   #1
Novice Travel Trailer Guy
benchmarks's Avatar
Hutch Mountain Eliminator Switch Install on Honda EU 2000I
For those familiar with this can you guide me through the connection wiring. Looks like that is all there is to it, but I just want to confirm which one to switch out. Appeared the factory wiring there is the choice of plugging to the existing 4-wire or 2-wire plug. Or should I be looking for certain colored wires? It looks like a good option to limit the gumming issue in Honda EU 2000i carbs.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2017 Chevrolet Silverado 1500 LT
benchmarks is offline   Reply With Quote
Old 12-10-2017, 07:39 PM   #2
benchmarks's Avatar
Seafoam fixed my generator issue. Before I could only rub with choke on. The Seafoam cleaned out the crud and now it runs perfect. Iíll be sure to not leave the gas sit in the carb over winter. This aftermarket switch will allow you to run your gen's carburetor dry prior to storage on a Honda generator. The Eu 1000 doe not give you that ability. Well I noticed no responses so i presume no one knows about the install of. If something changes let me know. Thanks.
Old 12-10-2017, 07:48 PM   #3
I created a thread on Seafoam and my Honda2000. It worked for me, also. In the winter fill it with pure gas and a little Seafoam and it will be good as new next year.
carlsbad is offline   Reply With Quote
Old 12-10-2017, 08:53 PM   #4
NMWildcat's Avatar
I know that nobody in my group drains fuel from their generators prior to storage. We all use Sta-bil. Never had any problems. No need for any switch. My Honda's are almost 12 years old now.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-10-2017, 09:13 PM   #5
benchmarks's Avatar
Congrats
Old 12-11-2017, 12:11 PM   #6
LSA pilot
Do you mean engine kill switch?
Simple, open large access door, look at wiring on bottom right that show a green and black wiring plug matching your new switch colors, disconnect original and plug in new switch connector. Did you not receive a small instruction sheet with yours?
If not look at the Honda EU2000i craigs list Myrtle Beach, SC site as I have some pics there that may help in locating switch install location.
palmettoe is offline   Reply With Quote
Old 12-11-2017, 12:32 PM   #7
LSA pilot
EU2000i engine kill switch
It works very well, but still should drain float bowl as there is normally a bit of fuel remaining, simple task.
Old 12-11-2017, 12:54 PM   #8
2X use sta-bil on all my small engine's
Tim
TimVWulp is online now   Reply With Quote
Old 12-11-2017, 01:43 PM   #9
Bluepill's Avatar
This^^^^
FWIW, Honda recommends StaBil brand stabilizer.
During use season I run all my power equipment and motorcycles on E-10 fuel. At the end of season, I drain the tanks with a siphon or carb drain, then add some E Free gasoline with StaBil and run for 10 minutes. As is usually the case, a little time spent on maintenance reaps the benefits of reliable performance.
2008 Itasca Meridian 37H
Old 12-11-2017, 01:43 PM   #10
benchmarks's Avatar
Thanks for the help on my 101 questions.
mount, switch
