Old 08-18-2016, 06:50 PM   #1
HVAC Tape?
So after the 2nd night on our maiden voyage I heard a rattle right above the quick cool vent. It was loud enough it woke me up.
I took the cover off and as I assumed a piece of the tape had come loose and was flapping.
Then I noticed that on the other side the tape was "sort of" put on between the wood frame and the air duct. I'm going to fix this but I want to make sure it's standard HVAC tape that is used. Here is a pic I tried to take of the offending area. There is about a 5/8" gap between the duct and that exposed wood. So my nice cool air is cooling my ceiling there.
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 08-18-2016, 11:20 PM   #2
Welcome to the cold ceiling club, I had the same issue and you should check your diffusers as you will probably have gaps there to. I did a post in ours and what I did. The metal HVAC tape will be fine to seal the up correctly.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 08-19-2016, 04:59 AM   #3
That's probably not a bat idea. There was one I had the dealer fix during the walk through. It had a rattle and they found clear plastic and other stuff just flopping around in there.
Sent from my SM-G900R7 using Tapatalk
Old 08-20-2016, 06:26 PM   #4
I used Gorilla Tape on ours. Check all vents as well. Also, close off the ductwork after the last vent. I just shoved a towel on ours. It's nice to actually have the cool air blow into the coach and not the ceiling.
Sierra360PDEK is offline   Reply With Quote
Old 08-20-2016, 06:37 PM   #5
What do you mean close off last vent?
Old 08-20-2016, 10:50 PM   #6
Gorilla tape as well as duct tape will tend to dry out over time. That's why it's no longer used. The proper tape to use is the foil HVAC tape as the alum will keep it sealed and not deteriorate.
Motofixxer is offline   Reply With Quote
Old 08-21-2016, 06:34 PM   #7
Don't seal off the last vent, block off the duct just past the last vent. On our fiver there is around 24" of dead space past the last vents.
Old 08-21-2016, 07:03 PM   #8
f5moab's Avatar
Sure does. I read that 'duct' tape should never be used on heating 'ducts."
f5moab is offline   Reply With Quote
Old 08-21-2016, 09:09 PM   #9
I actually picked up 3M tape made for rigid or flex duct. It was a few dollars more but I'll have enough for seemingly ever
Old 08-30-2016, 06:51 AM   #10
SilhouettePenny's Avatar
Don't forget to check the stove fan exhaust port, roof vent trim rings and propane heater ducts, mine were just stapled onto the heater box, I suppose this is why they claim the basement us heated. You'll need more than one roll of cold weather silver duct tape.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2016 - 43
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
