Old 03-12-2016, 06:40 PM   #1
Hydraulic jacks leak down
My fifth wheel hydraulic jacks leak down some (every once in a while)and aren't completely leveling from side to side. Fluid level appears to be ok, any ideas?Thanks
ClayP is offline   Reply With Quote
Old 03-13-2016, 07:23 PM   #2
It is not uncommon to have a little leak down, that is what I was informed when I contacted Lippert regarding some snapping and popping. (Another issue) Their suggestion was to re-level every few weeks.
Regarding the side to side level. If you have the auto leveling system you may need to manually set the unit to level and re-zero level the system. When we got our Silverback it was terrible, I had to do a re-level of the system. Has been good since. FYI I used a 4 foot level on the floor to get it correct each way. I don't trust the small exterior levels.
Rich5117 is offline   Reply With Quote
Old 03-14-2016, 12:13 PM   #3
That's very helpful, thanks!
hydraulic, jacks, leak
