Forest River Forums
Sunline User Photos
Old 12-16-2011, 10:33 PM   #1
Ice Shanty - Camping @ ice fishing
Does anyone have anyone have experience camping in very cold conditions? We're taking the M/L 23lb on an ice fishing outing in January, 2012. Our plan --
1) bring extra propane (1 extra 20 LB tank)
2) bring the genni - honda 2k (after having it serviced)
3) set-up the Olympic Wave heater (will use less fuel and no battery)
4) we will not use the water system, but will use gray and black holding tanks with some pink rv antifreeze
5) use pink rv antifreeze to flush toilet.
below is a photo from our first outing on an ice fishing camp out. It got a little chilly - but we did just fine.
teamgl is offline   Reply With Quote
Old 12-17-2011, 09:34 AM   #2
Moderator
mtnguy's Avatar
1st of all, the tow vehicle pictured is does not have near enough tow capacity for that sized trailer.
A lot depends on how cold the temps are going to be and how long you stay whether the extra propane bottle is going to be enough.
If using the Wave Heater, adequate ventilation is a must !!! If you are not camping around other people, an option might be to run the genny 24/7......the genny should keep the battery charged so you can run the furnace instead of having to use the Wave Heater.
Flushing the toilet with antifreeze might work....but will be a little expensive. If you are in an isolated area instead of a campground, making a yellow hole in the snow would be an option instead of peeing in the toilet and diluting the RV antifreeze. You can use the toilet for more important things , keeping in mind that there needs to be plenty of fluids (in this case RV antifreeze) in the tank to keep the solids from adhering to the tank.
The gray tank would be more of a concern. You would really need to keep the concentration of RV antifreeze high to counteract the water going down the sink and shower drains.
If your trailer has an enclosed underbelly with furnace ducting in that area, that would be another reason to run the furnace instead of the Wave Heater.....it would keep the tanks warmer than the outside air. But I would still want 100% antifreeze in the dump lines, because they would be outside of the heater area. A couple gallons in each tank right off to fill those voids might be necessary.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
Old 12-17-2011, 05:25 PM   #3
Thanks, Chap --
We'll definitely use the holding tanks sparingly. The initial plan is to camp two nights.
Here are some more photos from our first outing.
» Online Users: 701
151 members and 550 guests
5Galvs, Alisa06, artnlisa, bagged123, BeagleIL, Bearcat55, bikendan, BlakeB, bo criswell, bob213, boubou, brady, buckeyefan, Buffalohunter, Cafjackracing, Cascade Bob, cat1956, CCrane2299, cdbus, chof16, clarktod, ColoradoGreg, Cowracer, creed, cstover, cyclepuck, DAISY BOYKIN, danielpburke, danred, dapersico, DAREK.NIEUWSMA, davidjb, dfrauhiger, djorgensen3, doc73, donn, doosterhouse, drobert, duchie, dunnnc, dustman_stx, dville_v-lite, emljr, Emptypockets, f1100turbo, Falcon35, Fire Instructor, Foneguy, gator14, grhodes50, hairmommy, HemiCab, Hilgy, hokiecampers, hotrodj125, Iggy, iluvlcy, irish01, Itsthetwoofus, jamesroadking, Janet H, jar3316, jaydub3000, jrb988, kegoneill, ken0042, Kevin-and-Julie, KKapa, klucas, KyDan, lbrjet, ldmcmahan, LFugate, lmcleister, lochsa, Lonewolfcry, Loopyhamil, lowbubba, Malco, manvel, Mark S, mbrwr, mhartzel, michaelpike, Mickey1, MIKE44460, milw156, Mnflyboy, nailit, ncgrl1, Nursx2, OffPavement, PAMROBERTNC, pandkm, papap, PaulK, phone man, photog, Piston, pmsherman, popbreed, Ptmaazx6, punkaccountant, racedaymechanic, RattVader, redfox217, Retired63, rgmiller32, rick51, rkswyo, Rogue69, rotorhead1250, SabreSam, sail2liv, Sailfish Bret, Savage, scout800, scroses40, SDENN4281, shane1234, shrimper, silly2635, SimchaSabre, skeeterbait8, skennedy, Snowsail, stevem4134, sunbumnj, T.Kott, TacBear, tbritt, tedstr, Tee, Test Account, texashatter, Timex, Titleguy, tlc, tmmar, travyp, Triguy, Vernk, Vette4trcr, vlite2011, wagon52, Warrior, wayne anthony, whj77372, william.migues, wolfpack21643, Zadnichek
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
