Old 06-02-2014, 04:30 PM   #1
im in need of help I need an axle part #
I have 03 forest river wildwood 27bh, the axle is bent and the numer on the axle isn't legible enough to read, does anyone have a part number I could use so order a new one, any help would greatly be appreciated ! Thanks
painter01 is offline   Reply With Quote
Old 06-02-2014, 06:44 PM   #2
H2oski
Have you tried to get the info from Forest River? If they can't help this might work.
This is only a guess, but if you have springs, looking at your Specs : Hitch weight: 700
GVWR: 7,530 you need a 3500lb axle. Check out the link and take a couple of axle measurements (overall length and saddle spacing). With that info you can order a new one from this link:
3500 lbs Trailer Axles | etrailer.com
Good luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 06-02-2014, 06:52 PM   #3
AquaMan's Avatar
If you don't mind me asking, how did you come to the realization that the axle is bent? Just want to make sure you know that they are designed with a pre-loaded bend to them.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-02-2014, 07:42 PM   #4
Its bent at the spindle/hub, my camper place is emailing forest river with my vin # for direct fitment, but just incase I wanna see if anyone has any info on thia axle, just incase someone gets lazy and decides to forget about, kinda the impressionn I got from them, they dont want to order me one with out part number just incase its the wrong one, my axle measures approx 77" from hub plate to hub plate, I believe its a 3000lbs axle
axle
