Old 05-06-2019, 11:40 PM   #1
In dash ac
I have a 2003 Coachmen Mirada class a motorhome. At this writing I have a electrical problem with the in dash ac. The compressor and clutch are working but I have no power from the power distribution box to the clutch. I believe I have a bad fuse or relay for the AC but the power distribution box does not identify what each fuse or relay powers. The inside of the power distribution refers you to the owners manual which also does not give you any information to identify which fuse and relays control the power to the AC. Can anyone give me any information about the fuses or relays that power the AC or a contact that can provide this information.
gmannix is offline   Reply With Quote
Old 05-07-2019, 05:20 PM   #2
Failure is my business
2Evil4U's Avatar
Are you sure you have refrigerant? I've had systems stop running the compressor when the pressure in the system gets too low so it doesn't damage the compressor. Or the pressure sensor itself could be bad. Just a thought.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
