Old 09-18-2019, 09:15 PM   #1
Interior "Wood" and "Trim" water damage question
Last season we had an "incident" where our kitchen drain pipe disconnected from the drain line under the slide in the kitchen. Some water came out from under the slide and pooled on the floor for about a minute until we noticed what was going on. We quickly dried the mess up but on parts of the trim that meet the floor where water touched we wound up with the damage in the attached picture about 2 weeks later.
It's not something that bothers me until I look at it and as we are thinking of selling to upgrade I'd like to fix it.....without ripping out the damaged areas and replacing.
Thought I would post here and see if anyone had an idea.
stantyszka is offline   Reply With Quote
Old 09-19-2019, 06:36 AM   #2
Dodge Guy's Avatar
I had similar damage. My neighbor is a wood worker. We cut it above the damage and cut a piece of oak to fit the spot. He then routered it and put a nice design in the front of it. This was on the bottom of the slide out side trim. So we did both sides so it's matched.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 09-19-2019, 07:21 AM   #3
Dodge Guy has a great idea. That vinyl covered MDF will not accept a finish. Loweís, Home Depot and Menards all have decorative Plinths for use at the bottom of door trim.
https://www.lowes.com/pl/Plinths-Mou...ork/4294518234
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is offline   Reply With Quote
Old 09-19-2019, 10:44 AM   #4
Would you be able to post a picture of what you did? Trying to envision it and for some reason, coming up short.
Old 09-19-2019, 12:25 PM   #5
Dodge Guy's Avatar
I don’t know if I have a picture. And we traded it in on the Georgetown. I’ll see if I can find something.
Old 09-19-2019, 01:21 PM   #6
Hereís an example of a plinth block used on door casing.
Old 09-19-2019, 03:36 PM   #7
FORKLIFMAN's Avatar
Quick easy fix.... find a crayon or sharpie the same color as the Vynil cover? color it in, you be surprised how it works. Your eyes won't be drawn to it. for someone that doesn't know it is there, will never notice it!
Cheers David
FORKLIFMAN is offline   Reply With Quote
Old 09-19-2019, 04:34 PM   #8
Dodge Guy's Avatar
Originally Posted by Funengineer View Post
Hereís an example of a plinth block used on door casing. Attachment 215362
Yep, very similar to what we did. And itís real wood so it wonít do that again.
And yes a crayon will work. But itís not a permanent fix.
Old 09-19-2019, 04:48 PM   #9
Cheers David
Brown wax shoe polish, like Kiwi, is also a quick way to hide the discoloring. The plinth idea is a great permanent fix, albeit a bit more work.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-19-2019, 08:07 PM   #10
Here you go!
Here you go! Just put another layer of vinyl on.
https://www.amazon.com/Ultra-Honey-A.../dp/B000KKIR0A
I picked this color arbitrarily (I'm color-blind.). But it comes in many other colors and patterns. Search the internet for "wood grain contact paper".
Larry
Larry-NC is offline   Reply With Quote
Old 09-20-2019, 03:52 PM   #11
We bought our with a similar issue, the 'paper' fake wood has lifted a bit at the floor level under the sink. I've been meaning to replace it for 2-years now
I did look at some nice pieces in Home Depot, it's on my 'back-burner' to-do list.
Steve
2013 Sunseeker 2650
2015 Jeep Wrangler
stevemoores is offline   Reply With Quote
Old 09-22-2019, 04:03 PM   #12
Don't sweat the little things
If your selling, sell. If your trading, trade.
If you sell and someone says something about it give $100.00 off the price that you have already added $100.00 to so you can give $100.00 off.
If you trade the dealer will not care one bit. NOT ONE BIT! They will sell it just like that and not think twice about it.
Don't sweat the small stuff especially if you are getting rid of it.
campers302 is offline   Reply With Quote
water
