Old 12-07-2013, 04:21 PM   #1
Intervac System
We have a built-in Intervac system. The bag has been installed in the system and runs, but we get no suction. I checked the bag and there is no hole in the bag and I also checked to make sure there were no kinks in the lines underneath and all lines are clear. Any suggestions on why the system is not providing any suction?
Tom & Tracey
2013 Cardinal 3850 RL
2013 F250 King Ranch
tnoonan50 is offline   Reply With Quote
Old 12-08-2013, 09:54 AM   #2
Dave_Monica's Avatar
I don't have the answer but here's a link to their web site and contact info... Vacuums for your Home, R/V, Garage and Yachts - interVac Design
Dave
Old 12-08-2013, 10:42 AM   #3
Witch Doctor's Avatar
Dave
Dave just how do you find all this stuff all the time, and you always supply a link.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-08-2013, 10:51 AM   #4
Google Search is my best friend!
Dave
Old 12-08-2013, 11:02 AM   #5
litgrep's Avatar
Check:
Cover tight on the front of the unit
Suction bypass on the hose
Obstruction in the hose or cut in the hose.
Does the motor speed up when you pull the hse off the front of the unit, then the obstruction is in the hose. If not then, bag full or filter in unit is clogged.
litgrep is offline   Reply With Quote
Old 12-16-2013, 12:14 PM   #6
Old Enough to Know Better
gasman6674's Avatar
There is a foam filter between the motor and bag make sure its clean, You might take a shop vac and reverse suck from the hose connection with the bag out and cover off. PO on our rig used it with out a bag and it was a big mess.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
