12-18-2018, 07:24 AM
Taberry
Inverter
The inverter in my sandpiper 389rd stopped working Does anyone know if there is a fuse or where the inverter is located Thanks
12-18-2018, 08:14 AM
what type/brand/size is the inverter? does it power all the outlets or just the fridge?
12-18-2018, 09:36 AM
Taberry
inverter
I don't know the type or size, it only powers the fridge. There is a switch on the control panel, but no breaker or fuse in the fuse box. There is a breaker for the fridge, the fridge works fine on shore power.
12-18-2018, 09:53 AM
the inverter itself usually has a push button fuse reset on it
The Turners...
12-18-2018, 11:10 AM
Taberry
But we can’t find the inverter
12-18-2018, 11:12 AM
who knows, maybe in a cabinet, under the bed, in a storage bay(mounted on the ceiling!), etc... or even under the fridge...
12-18-2018, 02:21 PM
inverters are normally very close to the batteries. go to the battery and trace the battery cable for 3 or 4 feet and i'll bet you find the inverter. look at the ceiling of the battery compartment.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
12-18-2018, 02:30 PM
Taberry
I found the inverter, it is in the storage compartment near the steps
12-18-2018, 02:46 PM
OK great!
Now what did you find wrong?
12-18-2018, 04:09 PM
Taberry
Don’t know yet Turning on and off doesn’t work so we are trying to replace the fuse
12-18-2018, 04:55 PM
Some models have a small reset button on the back. Difficult to see (or feel). Was the problem on my neighbor's last year. One push and he was back in business.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
12-18-2018, 06:06 PM
Coach
Double check that your switched properly. If your inverter is wired like ours is the power button on the inverter has to be off for the on/off switch at the control panel to operate it. I believe ours has a blade fuse in the back for the 12volt side. There could well be an inline fuse between the inverter and the battery as well.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
12-24-2018, 10:23 PM
Measure the voltage in and make sure you have a good 12vdc. Measure the voltage at the outlets on the inverter to see if you have 110vac coming out. Inverters have a lot of fail safes (under voltage, over voltage etc). If the issue is not resolved the inverter will turn the output voltage off as a safety measure.
2018 fR3 30ds. Victron multiplus 2 2x120 24 volt lifepo4
