Old 07-19-2011, 01:49 PM   #11
Thank everyone for all the suggestions. I have been doing alot of reading. I was not very educated on rv electrical systems, as you could probably tell by me calling it an inverter LOL. My main question now is can/will we be able to use 120v without a converter if the batteries are fully charged for any 12 needs or could we cause more problems?
Thanks.
Lenna is offline   Reply With Quote
Old 07-19-2011, 02:04 PM   #12
MtnGuy's Avatar
Originally Posted by The_Stuff View Post
is it 50 or 30 amp service? 30 has 3 big prongs and 50 has 4 big prongs on the plugin to the hookups. if its 50, maybe one "leg" of the plugin isnt making connection and is the reason the AC wont go?
Good thinking !!
Leena, what camper do you have ??
Old 07-19-2011, 02:12 PM   #13
We have a 2006 Rockwood 26FT with one slide.
Old 07-19-2011, 02:30 PM   #14
MtnGuy's Avatar
I could not find a 26FT for 2006.
Does the cord that plugs into the camper have 4 prongs or 3 prongs ???
Old 07-19-2011, 02:34 PM   #15
it is a 3 prong
Old 07-19-2011, 02:47 PM   #16
MtnGuy's Avatar
The you have 30 amp service, and wouldn't be having the issue that The Stuff referred to.
Old 07-20-2011, 03:45 PM   #17
our refigerator is working off the battery butthe trailer is pluged in to 110 and it is not keeping the battery charged if you disconect battery the fride quits
hobbsabc is offline   Reply With Quote
Old 07-20-2011, 04:05 PM   #18
Boyd's Avatar
In my rig if I unplug shore power the fridge will shut down unless I have it programed (Push the correct button) to switch to propane automatically.
Do you have propane in your tanks?
Check the voltage of your battery with the inverter off, (Unpluged) just to make sure you don't have a dead battery.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 07-20-2011, 04:34 PM   #19
I would like to thank everyone for their replies. My husband found a fuse under the front of the camper that was blown (that was causing the DC problem). We now have 110 power and 12V power but the converter is bad, so the batteries wont charge. We will be taking a battery charger with us. We have owned this camper(2006 Rockwood RLT2603) since 3/08(purchased new) and this will be the 3rd converter. Anyone else have these problems?
Old 07-20-2011, 06:18 PM   #20
Villa Estate 392FLFB
The_Stuff's Avatar
if its a 3rd id have the wiring inspected... something is slowly burning out the converters.
One state/province at a time!
The_Stuff is offline   Reply With Quote
bypass, inverter, power
