Old 07-21-2011, 09:52 AM   #21
Originally Posted by Boyd View Post
In my rig if I unplug shore power the fridge will shut down unless I have it programed (Push the correct button) to switch to propane automatically.
Do you have propane in your tanks?
Check the voltage of your battery with the inverter off, (Unpluged) just to make sure you don't have a dead battery.
How do you turn the converter off
hobbsabc is offline   Reply With Quote
Old 07-21-2011, 12:59 PM   #22
Boyd's Avatar
Your converter will go off when you unplug from shore power, which is the same as a 120 volt supply. Unplug the power cord that runs from your trailer/camper/motorhome to the outside electric source and your converter will go off.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
bypass, inverter, power
