Old 01-11-2019, 04:15 PM   #1
Inverter removed What issues will this cause?
I have a 2002 Sunseeker class C. The inverter had damage and was removed with some wiring. What issues should I expect besides no ac voltage. This unit does have a generator so I can get power that way if needed. Does this effect charging the rear battery? Should I wire up a trickle charger to this battery? When I checked battery fluid it was low in 2 cells.Thanks
baldrudy is offline   Reply With Quote
Old 01-11-2019, 04:29 PM   #2
bikendan's Avatar
Do you mean a CONverter, instead of an INverter?
Unless a previous owner installed one, dont think Sunseekers came with a factory inverter, in 2001.
Equalizer WDH
Old 01-12-2019, 05:53 AM   #3
not sure what type of __verter it was. It was under the bed and had 2 large cables going to the battery and romex to the breaker box. This is on a 2002 sunseeker not 2001.
Old 01-12-2019, 07:12 AM   #4
western NC mountains!
formerFR's Avatar
without your Converter your House batteries won’t get charged - you’ll need a separate 12v 3 stage Charger - you can plug it into one of your outlets while the generator is running, or on shore power.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 200w/10amps mobile SOLAR
85,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
Old 01-12-2019, 08:52 AM   #5
cavie's Avatar
If it was an Inverter (changes 12 volts to 120 volts) I dought that it controlled all your AC voltage. That comes from shore power and/or generator. Inverter probably supplied a residential fridge, TV outlets. BUT I have known to be wrong in my statements hench the bold probably
If you have a residential fridge you need the inverter.
A converter changes 120 volts to 12 volts. It will have 12-volt fuses attached to it.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-12-2019, 09:16 AM   #6
wmtire's Avatar
This thread may help, as it explains WHAT they do in your RV and the items that are controlled by each:
Converter or Inverter (they are different)
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 01-12-2019, 09:48 AM   #7
Coach
In order for folks here to help you, you'll need to give us some more info. What is the make/model of the device you removed? Inverters and converters are wired very similar but serve very different purposes. The more info you can give, the better advice you will usually receive.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is online now   Reply With Quote
Old 01-12-2019, 11:01 AM   #8
cavie's Avatar
It sounds like the Previous Owner removed the device.
Old 01-12-2019, 12:48 PM   #9
Correct the device has already been removed. I just have battery cables that go from under the bed to where the battery is and they are disconnected.
Old 01-12-2019, 02:26 PM   #10
Pictures help too. Sometimes we might see something the original poster doesn't realize is important to solving the mystery.
Skip12 is online now   Reply With Quote
inverter
