Old 08-18-2009, 08:18 PM   #1
rvron's Avatar
Is their an outdoor stove to compliment my sidekick grill?
Hi. I love my side kick grill that came with my 2601. I wish I could hook up a 2 burner stove next to it and do all my cooking outside. Does anyone know if there is a stove that uses the same "quick connect" system? or is there an adapter that I could use with another brand, ie: Coleman? I'd much prefer using the gas from my rig's tanks rather than hassling with those little canisters. Thoughts anyone?
rvron is offline   Reply With Quote
Old 08-18-2009, 08:52 PM   #2
You can adapt almost any propane accessories to use your quick adapt. I'm in the process of adding a quick connect to my new camper because I loved it so much on my last Jayco.
Max Power is offline   Reply With Quote
Old 08-26-2009, 08:32 PM   #3
Camp Stove
Last spring we bought a camp stove with two top burners and an oven. It came from Sam's. Our Forest River Daydreamer has a convection oven and we wanted a conventional oven we could use outside. The thing does a very nice job, is fairly compact.
Don C is offline   Reply With Quote
Old 08-27-2009, 02:42 PM   #4
SOMETIMES.... not always but sometimes, the outside gas supply is a LOW PRESSURE supply, and inside is a high pressure supply. BOTH of my Coleman pop up's were like this. I tried to run a Weber gas grille from a T on the outside that I put on there....NOT enough pressure. I went back to the small bottles for the grille. Randy
Old 08-27-2009, 04:19 PM   #5
Grape Escape
Can't understand why these portable stoves are setup for higher pressure. The stove burners inside the trailers run on 11"wc
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
