Old 11-20-2018, 04:57 PM   #1
Is this water leakage or glue
We bought a new 2018 Cherokee 264L last March and I didn't notice these stains until our 1st trip with it . I took it back to the dealer and was told these stains are from glue that leeched out , not from a water leak . Dealer said they would repair it but they would have to take the entire rear of the trailer off to replace the panels or put some wider trim pieces on to hide it better . We have towed it over 3000 miles and used it about 30 nights and been in several heavy rains and I can't find any sign of leaks or moisture anywhere . I really don't want them to pull the rear of trailer off to replace these panels if it's not from a leak ,but I also don't want to take an extra hit on it if I ever sell or upsize later . Would you have them repair it or live with it ?
ID:	191878Click image for larger version
Teamster4life is offline   Reply With Quote
Old 11-20-2018, 09:06 PM   #2
CincyGus's Avatar
To me, neither option is good. I certainly wouldn't want them taking the back wall of my trailer that isn't currently leaking and possibly having a leak afterwards. I also wouldn't be happy with myself for missing it during my PDI and now worrying about hurting the trade in or sale value.
IF I were you, I think I would be brainstorming on a way to hide the glue staining because everyone that see's your trailer or looks at it if you go to sell or trade in is going to think the same thing you and I thought when we saw the pics. "oooooh, water damage" and your explanation is going to sound like BS because they won't know for sure.
I couldn't tell but are those two pics from the same wall? If so, maybe a good scrubbing with some coarse sandpaper, a coat of Kilz Primer and then a "Painted Accent Wall" is an option? Or some other less drastic solution than pulling off a wall.
Good Luck. I'll be following to see what you decide.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 11-20-2018, 09:55 PM   #3
Jayhawker
Jayhawker's Avatar
I would check paint stores like Sherwin Williams for a fabric backed vinyl wallpaper to cover the panels that are stained (Kilz applied over stains first).
Jayhawker is offline   Reply With Quote
Old 12-10-2018, 09:55 PM   #4
Personally, I would have them fix it.
Rich5117 is offline   Reply With Quote
Old 12-10-2018, 10:17 PM   #5
Oaklevel's Avatar
Attachment 191878Attachment 191880
Personally I would first make sure that it is not a leak. To have the dealer fix it properly, you will probably loose the use of the trailer for the 2019 season or at least a good part of it.
I doubt that you will take a hit on trade in to a dealer, esp if you make it look good cosmetically. We have never had a dealer spend more than a minute inside of a trailer when evaluating it for a trade........ I can walk through the door spend 30 seconds in a camper and tell you if I am going to look further at a used trailer or move on to another one.........
Your decision though......... Good Luck
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 12-10-2018, 10:53 PM   #6
SlowrideHD's Avatar
Doesn't look like glue to me. That looks like water damage.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 12-10-2018, 11:16 PM   #7
looks like water damage to me//
2006 Silverado 1500 5.3l 3:42 rear 4l60 4 speed
2018 Coachmen SBX 261BH
Lawrosa is offline   Reply With Quote
Old 12-10-2018, 11:29 PM   #8
cavie's Avatar
a moisture meter will tell the tale.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-16-2018, 10:31 AM   #9
Kirk S's Avatar
X2
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 12-16-2018, 11:08 AM   #10
Phat Phrog Stunt Crew
elind's Avatar
If it's cosmetic on the wall, I would contact Cherokee factory for a piece of vinyl to match it. I had good size dents form chairs bump the walls. The techs from Wildcat came out and plastered over the dent and then glued the vinyl wallpaper matching the pattern. In the end the repair blended in.
2014 Wildcat 327ck
elind is online now   Reply With Quote
leak, water, water leak
