Old 07-29-2013, 11:13 AM   #1
dr ron
dr ron's Avatar
Is Turbo Operating?
I have a 2001 Forest River 33 ft. Reflection with a 330 Cummins Diesel Turbo.
I find that I always have the pedal to the floor more times than not.
How do I tell if the Turbo is functioning properly. The transmission is an Allison that does, downshift around 50mph.
dr ron is offline   Reply With Quote
Old 07-29-2013, 11:20 AM   #2
TURBS's Avatar
If the turbo wasn't working you wouldn't be going anywhere .
Air to air cooler may be leaking.
Old 07-29-2013, 11:20 AM   #3
daydreaming about camping
jeeplj8's Avatar
in the simplest terms, unless the exhaust is a steady stream of thick black smoke in virtually all conditions, the turbo IS working. As to how well, well that is another question. You should be able to get a scanner for that Cummins to show you many parameters including boost pressure.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-29-2013, 11:36 AM   #4
dr ron
dr ron's Avatar
I have a scan gauge but I haven't entered any codes yet because I don't know where to find the codes.
It connects to the diagnostic computer port.
Old 08-27-2013, 05:18 PM   #5
Spikedog's Avatar
Scangauge's website will have the right codes to add in. Do you have the right scangauge? There is a 'D' model for pushers, uses a different language than the one for cars & trucks.
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
Can't seem to get my head around the turbo question - if it's not working, you are not going anywhere. The scangauge should help you with boost and exhaust back pressure readings, although with a 2001 the sensors might not be that extensive. If you don't have a thermocouple or a pressure gauge already in place, the scangauge won't give you a number.
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 08-27-2013, 06:08 PM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
Maybe you are just trying to drive to fast!
Just kidding. When the last time you changed air filter, fuel filter.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 08-27-2013, 06:14 PM   #7
asquared's Avatar
ok someone has to say it.... I read the post title and just imagined turbs the surgeon. now my brain hurts and my eyes burn.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-27-2013, 06:21 PM   #8
TURBS's Avatar
He has operated the last two days
Old 08-27-2013, 06:26 PM   #9
B47
You should know that the Turbo we know here is always operating - not always for the good, but operating nevertheless.
B47 is online now   Reply With Quote
Old 08-27-2013, 07:04 PM   #10
Phat Phrog Stunt Crew
elind's Avatar
X2
2014 Wildcat 327ck
elind is offline   Reply With Quote
