Old 05-10-2011, 01:34 AM   #1
2003 Sunseeker 3100SS
Nursx2's Avatar
Is white wire ground?
OK, installing a rear camera on my 2003 Sunseeker class C 3100SS and I need help. Got the panel off the rear upper cabinet and have the rear clearance light wires exposed. One white and one green. Which one is the ground wire???
I am thinking white as all the wires in the junction box are white and some other color. Any thoughts????
Nursx2 is offline   Reply With Quote
Old 05-10-2011, 06:45 AM   #2
Herk7769's Avatar
Since they used whatever was on the roll at the time when RV manufacturer's build campers, there is no telling what any wire does or where it goes.
However, in my 5th wheel, the guys who wired it used the white wire as a ground. The green one as power to just about anything that uses electric.
HAM CALLSIGN - KC3FFW
Old 05-10-2011, 06:47 AM   #3
KyDan's Avatar
Lou is correct but you really need a meter to check for sure.
Don't assume any color means anything until you check
with a meter!!
(You can get cheap digital multi meters at Harbor Freight
and Radio Shack)
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-10-2011, 06:55 AM   #4
Herk7769's Avatar
That will save money on fuses for sure!
Old 05-10-2011, 07:01 AM   #5
I think it"s amazing that the manufactures don't follow/have an industry standard. Green wire for power cmon??? My tt uses black for power and white for ground.
2009 Rockwood 8315BSS
1999 Chevy Tahoe
Pullrite Anti-Sway Hitch
nycamper is offline   Reply With Quote
Old 05-10-2011, 07:13 AM   #6
Herk7769's Avatar
In this photo one G/Y wire goes to Left Slide Motor; another G/Y goes to Right Slide Motor; a third goes to Fresh Water Tank Heater; the fourth is power to the Concertone and ceiling lights in the L/R (I think).
Jeeze I just realized looking at the picture again it was not Green and White but Green and Yellow. The Yellow one is ground (most times).
I do have several white grounds though. See second photo.
Name:	Horst Probe Install 020.jpg
ID:	5733   Click image for larger version
Name:	Horst Probe Install 017.jpg
Old 05-10-2011, 07:25 AM   #7
The tt industry really needs to settle on one standard and not each have their own. It has to be pretty confusing for the repair guys. Went out and took a second look at mine and my tt has red for power (not black) and white for ground. My previous tt had black for power and white for ground.
1999 Chevy Tahoe
Old 05-10-2011, 07:31 AM   #8
Herk7769's Avatar
Standard?
There is no rhyme or reason to any wiring in my camper; let alone among manufacturers. Just try to get a wiring diagram! The Dealers do not complain because every job is charged out "Troubleshooting Labor" "Parts" and "Installation Labor."
The Troubleshooting is always more than the Install. Now you know why.
