Old 09-14-2016, 01:09 PM   #11
JustB_Rad's Avatar
Originally Posted by Witch Doctor View Post
If I were you guys I would be checking the spring to make sure they have enough winds in it. It is my understanding that when you bring in the awning the spring does most of work. It winds as it go's out then unwinds to assist the motors. Somebody please correct me if I'm wrong. Just unplug the motor and connect 12 volt to the 2 leads and try it. I think I remember that the spring has to be wound 11 times to set the tension. I have two awnings, so I bought 2 extra new motors from the salvage yard in Goshen. Last year they were 40.00 and this year they were 50.00 they do ship... PS: when mine start to strain, I put wd40 on the pivot points and it will just fly back in. If it's starting to shake bringing it in it's time to lube the pivots point.
My Lippert awning has no spring at all. Dometic and Lippert have 2 totally different systems.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017) at least 23 Nights Planned in at least 6 trips!
JustB_Rad is offline   Reply With Quote
Old 09-14-2016, 01:20 PM   #12
Left Coast
Thanks for clarifying which one you've got
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 09-14-2016, 01:23 PM   #13
JustB_Rad's Avatar
This was a thread about Lippert Awning Motor problems....I didn't think I had to....
Old 09-14-2016, 03:18 PM   #14
Yes, the awning on my 2016 Salem Light has not worked correctly since it was new. It will roll up backwards (with the underside of the awning showing), but will stall out if I try to roll it up correctly. The local Funtime dealership has tried to fix it twice, to no avail. I have been waiting on repair parts for 2 months, and the parts still have not arrived. Does anyone have instructions for checking and setting the spring tension on this awning unit? I was unable to find any online instructions. I don't know if my local dealership will ever get the new parts.
slowpoak is offline   Reply With Quote
Old 09-14-2016, 03:26 PM   #15
JustB_Rad's Avatar
If it's a Lippert Components Awning (LCI), it doesn't have a spring.
https://www.lci1.com/assets/content/...awning-web.pdf
Old 09-14-2016, 05:16 PM   #16
Witch Doctor's Avatar
This is true, loop looked it up, just a gear, I might be wrong but being DC couldn't you just switch the wires, just a question
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-14-2016, 05:18 PM   #17
I don't like auto correct, on taptalk
Old 09-14-2016, 08:00 PM   #18
"But my Funtime Repair Ship Said........."
Hmmmmm. I thought there was a tension spring in the idler asm. because my Funtime repair shop said my awning drive motor was weak and my tension spring was stripped out. But that was 2 months ago and repair parts still aren't here. If there is no spring, I may try reversing the wires to the motor to see if that works. But they have worked on it twice; if that was a fix, you would think that they would have tried it. Thanks for your info about the spring, though; I'll try wire reversal. Oh, and it is an LCI.
Old 09-14-2016, 08:31 PM   #19
HalfBubbleOff's Avatar
Same problem with my 2015. Awning goes out fine but will not roll back in at all. Have to use the drill method. Thanks for the info. I will take mine in and get the motor changed out.
Ron & Ann
2016 Wildwood Heritage Glen 282RK
2015 Silverado 1500 5.3 355hp 3.42 rear gears
HalfBubbleOff is offline   Reply With Quote
Old 09-14-2016, 08:51 PM   #20
Motor on my 2015 lasted exactly one year and was replaced under warranty. The replacement has been struggling all year. If the awning bracket is adjusted so that the awning is in it's highest position (parallel to the ground) the motor can't wind it in by itself. If the support bracket is adjusted so that the awning slopes quite a bit the motor can roll it up.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
awning
