Old 09-14-2016, 11:25 PM   #21
RetiredRVer
Mine failed after 1 1/2 years on my Heritage Glen TT.....had it replaced at Goshin this year and all is well now.
Joe & Sandy
Mentor, Ohio
2015 Chevy 2500HD Crew Cab 4X4 6.0 "Gasser"
2014 Wildwood Heritage Glen 282RK TT
2018 "FROG!" To Alaska
checkmate99 is offline   Reply With Quote
Old 09-14-2016, 11:37 PM   #22
My awning would extend ok but made some noises when retracted. It would retract back slowly. Found out my problem was the awning arm struts/pistons. I lubed the shafts and haven't had a problem since.
Bob
2013 Ford F250 SD 6.7L
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 09-15-2016, 07:48 AM   #23
Camp Bartender
I haven't greased the arms myself, but the Tech did say that the motor was taking a crap. The service manager also said that there supposedly "isn't" a problem with them, but they are going bad. I figure that if there wasn't an issue, Lippert wouldn't have a few month backorder on awning motors. Regardless, my awesome dealership is getting me all squared away.
2013 Dodge Ram 1500 Express, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015: 7 Trips, 20 Nights Camped
2016: 7 Trips, 23 Nights Camped
2017: 5 Trips planned (so far)
stevensmith2859 is offline   Reply With Quote
Old 09-15-2016, 07:14 PM   #24
Good thought on the wire reversal, Witch Doctor, but that did not help. Anyway, thanks for the idea. Guess I'll keep waiting on the parts that the dealership ordered.
slowpoak is offline   Reply With Quote
Old 09-15-2016, 11:42 PM   #25
Originally Posted by Witch Doctor View Post
If I were you guys I would be checking the spring to make sure they have enough winds in it. It is my understanding that when you bring in the awning the spring does most of work. It winds as it go's out then unwinds to assist the motors. Somebody please correct me if I'm wrong. Just unplug the motor and connect 12 volt to the 2 leads and try it. I think I remember that the spring has to be wound 11 times to set the tension. I have two awnings, so I bought 2 extra new motors from the salvage yard in Goshen. Last year they were 40.00 and this year they were 50.00 they do ship... PS: when mine start to strain, I put wd40 on the pivot points and it will just fly back in. If it's starting to shake bringing it in it's time to lube the pivots point. You might call dometic they can tell you how many winds for sure. Be Careful there is alot of tension on the spring.
Doc.....please tell me about the salvage yard in Goshen. Is there a website or phone number you can share.
Thank you
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags.
2011 28RKS Wildcat. Yamaha 3000iseb Generator.
2013 22 nights.2014 57 nights.2015 116 nights +14300KM
2016. 96 nights
Filterman is offline   Reply With Quote
Old 09-16-2016, 12:56 AM   #26
Witch Doctor's Avatar
I'll have to find name out for you and get back to you, it's a couple miles down the road from the fairgrounds. This Amish guy has about any part you could think of. .....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-16-2016, 07:35 AM   #27
Thank you
I got the info for you from Sid Brown here it is, use to be called D&D but changed the name but here is the info
We think its called Petunia's now:
12678 county rd 34
Goshen In. 46506
574-642-3316
They buy salvaged trailers from everyone, and tear them apart. Like I said bought a new awning motor with only a small blemish on it for 50.00 bucks, they have everything that a trailer would need...Good luck..
awning
