Old 09-14-2016, 12:17 PM   #1
Camp Bartender
Issues with Lippert Awning Motors
I am taking my 2015 Wildwood 28DBUD back to the dealership to have the awning motor replaced. It goes out fine, but pulling it back in, a total different issue, it struggles terribly to retract it, to the point that its a snails pace. Took it into my dealer a few weeks ago, Tech said yes, its going bad (end of August) but that Lippert was backordered on motors until October at the earliest. Since my wife and I bought from a local dealer who provides GREAT service, not Camping world, the service manager actually called Forest River to have one pulled from the assembly line and sent to them. I needed to pick up the unit because of our Labor day weekend reservations, but am bringing it back on Saturday for a week so that they can install it.
Friends of ours have a 2015 Salem, and also needed their motor replaced. Anyone else have any awning motor issues? Thank goodness my dealership is standing behind the extended warranty because it would have been over 300 bucks for the motor.
2013 Dodge Ram 1500 Express, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015: 7 Trips, 20 Nights Camped
2016: 7 Trips, 23 Nights Camped
2017: 2 Trips, 5 Nights Camped (so far)
stevensmith2859 is offline   Reply With Quote
Old 09-14-2016, 12:29 PM   #2
JustB_Rad's Avatar
Yup, same exact issue. Mine was just before our week long trip for the 4th of July to our year old unit, and a helpful lady at my dealership, who's since been fired had it directly shipped to me. During my research, somebody had also found out that a window motor from a 1994 Chevy Lumina fit's the same bolt pattern and is also about 15% of the cost of the lippert motor. I purchased that as my backup now that I'm out of warranty.
Dorman part 742-141 - I Think I got it off of amazon for like $30
Cardone also makes a couple motors -
Part # 42-127 & Part # 82-127 for the select.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017)16 Night Booked in 4 Trips - 6 in 2 more Trips Planned
JustB_Rad is online now   Reply With Quote
Old 09-14-2016, 12:35 PM   #3
Yep, I replaced mine last month with a $39 window motor. Works great! The downside is that there is no mechanism to manually operate the awning with a drill in case of another failure. The new motor is much stronger. Be aware with the OEM motor that it takes a very strong 12v source to retract the awning. If your battery is not fully charged, even when connected to shore power, the motor will have a hard time retracting the awning.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 09-14-2016, 12:39 PM   #4
JustB_Rad's Avatar
I'm not sure I believe the battery thing....I replaced my battery, thinking it was screwed up from being drained and left dead with a brand new deep cycle battery and it made no difference. I also tested it without a battery and it was exactly the same as with a battery.
A weird tidbit....When my replacement arrived, it had the same exact date code on it as the one that went dead. The new one sounds a whole lot meaner though.
Old 09-14-2016, 12:45 PM   #5
Left Coast
How can you test without battery?
Old 09-14-2016, 12:47 PM   #6
JustB_Rad's Avatar
I had it plugged in....all my systems worked fine without a battery including my tongue jack.
Old 09-14-2016, 12:49 PM   #7
Left Coast
12 volt awning motor, 12volt jack motor.....running straight off converter
Old 09-14-2016, 12:52 PM   #8
JustB_Rad's Avatar
Yes...Pump and lights work too.
Old 09-14-2016, 12:54 PM   #9
Left Coast
Only thing that won't....breakaway switch, fridge, furnace and possibly A/c
Old 09-14-2016, 01:09 PM   #10
Witch Doctor's Avatar
If I were you guys I would be checking the spring to make sure they have enough winds in it. It is my understanding that when you bring in the awning the spring does most of work. It winds as it go's out then unwinds to assist the motors. Somebody please correct me if I'm wrong. Just unplug the motor and connect 12 volt to the 2 leads and try it. I think I remember that the spring has to be wound 11 times to set the tension. I have two awnings, so I bought 2 extra new motors from the salvage yard in Goshen. Last year they were 40.00 and this year they were 50.00 they do ship... PS: when mine start to strain, I put wd40 on the pivot points and it will just fly back in. If it's starting to shake bringing it in it's time to lube the pivots point. You might call dometic they can tell you how many winds for sure. Be Careful there is alot of tension on the spring.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
awning
