Old 07-04-2011, 12:14 AM   #11
kz08h5's Avatar
Bikendan said it: Get some wheel wheel chocks. Night and day difference when they are used.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 07-04-2011, 01:44 AM   #12
bikendan's Avatar
try the tandem wheel chocks first. most who do, get good results.
then, if there is still too much movement, then you can look at installing strut stabilizers, such as these:
http://http://www.ultra-fab.com/new_detail.cfm?mfgnum=48-979007
Old 07-04-2011, 05:37 AM   #13
Stevea1956's Avatar
Welcome to the forum!!
This is a highly discussed topic here in the forum.
If you type movement, shaking, or stabilize in the search box, you'll get plenty of tips and tricks from other members that have this issue. Myself included.
I'm not sure whether your TT is considered an ultra-light or not but if it is, you will find it nearly impossible to get it rock steady.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 07-04-2011, 07:12 AM   #14
KyDan's Avatar
My rear stabilizer jacks are mounted to a piece of light weight angle iron
that spans the width of the trailer. I know it flexes when the jacks are
down. Check yours. If you have similar set up you might consider
adding another angle iron on top of the one that's there.
I also use a wheel chock on one side. I never got the 2nd one for
the other side because we're mostly satisfied with stability now.
(No kids running around inside.)
Google RV wheel chock and there are several different kinds and a pretty
big span of prices.
I have one of these Ultra-fab Products - Deluxe Chock & Lock - Chocks & Levelers - Camping World
Once you adjust it you don't kneed any tools to apply or remove it.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-04-2011, 08:15 AM   #15
We always have movement in our camper and we have power front and rear jacks and you can ply put them down so far so we always have movement because if you try to level the camper with them they will max out and you will have to use the hand crank
Matthewsbj1 is offline   Reply With Quote
Old 07-04-2011, 09:15 AM   #16
KyDan's Avatar
Stabilizing jacks are just that- stabilizing.
You have to level your trailer first by putting blocks or planks
under the low side tires until it's level side to side.
Then adjust the tongue jack to get front to back.
Then put down the stabilizing jacks to cut down on that bouncy feeling
when someone is moving around inside the trailer.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-04-2011, 09:59 AM   #17
Wanna Be Camper
SaskCampers's Avatar
Interesting in that last year we never experienced bounce in our V-Lite. However the trip we are on now we brought DW's sister and hubby and well her sister is weight challenged and it provides for a bouncy time when she is moving around the trailer. Something we never noticed due to our lighter weight. We have 10" high stabilizer blocks I made to put the stabilizers down on as well as dual X-Chocks. It seems to me the bounce is coming from the flexing of the frame over the wheels due to the rubber suspension as our old Edgewater never did this and it had leaf spring suspension and was just a foot shorter and weighed about the same. Guess I'll do like Crocus and make my own steadfast stabilizer system and get a set of screw type jack stands to put under the frame between the wheels on both sides and see how that works. Also need to see how the stabilizers are mounted to see if I can stiffen that up without affecting the actual frame.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-04-2011, 11:24 AM   #18
RubenZ's Avatar
Get a Set of THESE
And then what I do is put some if THESE on the frame Close to the TIRES. It's the actual tires that cause bounce.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 07-04-2011, 12:19 PM   #19
Bikendan,
Do you recommend the X-Chocks or the model that are similar to normal tire chocks that extend on the ground to under each tire?
Thanks to all who have posted replies. This was awesone information!!!!!!!!!!
sally is offline   Reply With Quote
Old 07-04-2011, 02:35 PM   #20
The biggest problem is that no TT frame is made to support the trailer on any kind of jack. If you try, you will get frame flex with can cause alignment issues with doors, windows, etc. As mentioned earlier, they are stabilizers, not leveling jacks. From what I've tried, I like the X-Chocks the best.
caleb is offline   Reply With Quote
