Old 06-18-2014, 05:00 PM   #1
tmhyer's Avatar
Jacks down while in storage
Does anyone know if its recommended to NOT store your RV with the hydraulic leveling jacks down? Ive seen it both ways, and am not sure of the correct procedure.
Thanks for any help
2014 Sunseeker 3010DS, 2001 Jeep Cherokee toad
tmhyer is offline   Reply With Quote
Old 06-18-2014, 05:08 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
If it's hydraulic, I would say why not. It'd take the weight of the tires and if they would lose pressure during that time they wouldn't be ruined.
I do it.
Or am I wrong?
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-18-2014, 05:12 PM   #3
VinceU's Avatar
Thanks for any help
Have done it both ways, no glaring advantage to either. But if jacks are left extended you should lubricate the exposed pistons regularly with lube to prevent corrosion and pitting = leaks.
Old 06-18-2014, 05:13 PM   #4
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I've never heard a recommendation on this. IMO, since the jacks are stabilizer jacks and are there to help stabilize the trailer when you are living inside, there is no need to have them down exposed to the elements when in storage.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 06-18-2014, 05:31 PM   #5
Always store with jacks up it keeps the chrome on the rod protected.
lbrunning is offline   Reply With Quote
Old 06-18-2014, 05:55 PM   #6
Look at construction or farm equipment stored outside for many summers and winters, I have never seen rusted hydraulic cylinders in my life unless they were physically damaged.
Old 06-18-2014, 06:05 PM   #7
Thats because they rusted and were replaced. Store them up and protect them, makes perfect sense to me.
Old 06-18-2014, 06:20 PM   #8
Well, I once pulled an old hydraulic cylinder out of the ground and the only shiny part with no rust was the piston and I know farm equipment, trust me.
Old 06-18-2014, 06:32 PM   #9
Oh, I'm sure you do. I am not doubting what you just said, but think of this. Take the folks that are near saltwater, the highest grade stainless rusts. I was agreeing with the other poster who said store it in the up position. Its simple and eliminates the chance of rust.
Old 06-18-2014, 06:42 PM   #10
VinceU's Avatar
Bear in mind, farm equipment is probably triple chromed hd steel . RV jacks are nowhere near the quality.
jacks, storage
