Forest River Forums
Sunline User Photos
Old 11-21-2011, 01:55 PM   #1
kitchen faucet leak
I have a 2011 31kbhss Puma trailer and the kitchen faucet is leaking water underneath in the cabinet. I cant see where it is coming from. All the connections are tight and dry. I have owned this for 7 months and have only used it 2 times. Any ideas on what to do?
markt is offline   Reply With Quote
Old 11-21-2011, 03:23 PM   #2
Boyd's Avatar
Wipe the pipes completely dry, wait a minute or so and then SLOWLY run your fingers along the pipes, checking for water on your finger tips every few inches. Take a good flashlight or drop light under the sink with you and have someone standing near with the Bandaids when you smack your noggin on the way out.
Good luck
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 11-28-2011, 07:39 PM   #3
j2detroit's Avatar
you have to remember that when fr built our campers they didn't use the best of everything and they have this weight thing we replaced both the kitchen and the bathroom fausets with some much higher quality ones bought at our local menards store work great and look real good very easy to change out around 15mins for each one
j2detroit is offline   Reply With Quote
Old 11-28-2011, 08:31 PM   #4
RV Newbie
buzzards27's Avatar
Clear out the cabinet below the sink, dry off the area below the leak and lay paper towels down and watch. If it doesn't leak without water flowing turn on each valve and watch for the drip. It may be leaking from the drain.
Once you find the leak fixing it should be easy, may be as simple as snugging up a loose nut or replacing a washer.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 11-29-2011, 06:36 AM   #5
Boyd's Avatar
And sometimes a leak is nonexistant until the hot water heater puts pressure in the lines...
Old 11-29-2011, 08:02 AM   #6
RV Newbie
buzzards27's Avatar
Another possible source of leaks is a poorly mounted faucet or even a sink. If they are mounted without proper sealants or gaskets and you slop water around the base, they will leak. Check for a faucet that moves around.
Old 11-29-2011, 08:17 AM   #7
Villa Estate 392FLFB
The_Stuff's Avatar
also you on tank water or city water? i had to put a regulator in because the city pressure was past 85 psi some times!! even then say you have a shower, the built in check valve makes the pressure in the lines build up when it has finished heating up all the fresh water in the 6gallon hot water heater!
One state/province at a time!
The_Stuff is offline   Reply With Quote
» Online Users: 713
149 members and 564 guests
5Galvs, Alisa06, artnlisa, bagged123, BeagleIL, Bearcat55, bikendan, BlakeB, bo criswell, bob213, boubou, brady, Buffalohunter, Cafjackracing, camping4us, Cascade Bob, cat1956, CCrane2299, cdbus, chof16, ChrisZazzara, clarktod, ColoradoGreg, Cowracer, creed, cstover, cyclepuck, DAISY BOYKIN, danielpburke, danred, dapersico, DAREK.NIEUWSMA, davidjb, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, dustman_stx, dville_v-lite, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Foneguy, gator14, gmw65, grhodes50, HemiCab, Hilgy, hokiecampers, hotrodj125, Iggy, iluvlcy, irish01, Itsthetwoofus, jamesroadking, Janet H, jar3316, jaydub3000, jkinger, jrb988, kegoneill, ken0042, Kevin-and-Julie, KKapa, klucas, KyDan, ldmcmahan, LFugate, lmcleister, Loopyhamil, Malco, Mark S, mbrwr, mhartzel, michaelpike, MIKE44460, mikev, milw156, Mnflyboy, nailit, ncgrl1, Nursx2, OffPavement, PAMROBERTNC, pandkm, papap, PaulK, phone man, photog, Piston, pmsherman, popbreed, Ptmaazx6, punkaccountant, RattVader, redfox217, Retired63, rgmiller32, rick51, RJHuser, rkswyo, Rogue69, rotorhead1250, SabreSam, Sahgie, sail2liv, Sailfish Bret, Savage, scout800, scroses40, SDENN4281, shane1234, shrimper, silly2635, SimchaSabre, skeeterbait8, Snowsail, stevem4134, T.Kott, TacBear, tbritt, Tee, Test Account, texashatter, Timex, Titleguy, tlc, tmmar, travyp, Triguy, Vernk, Vette4trcr, vlite2011, wagon52, Warrior, washdweller, wayne anthony, william.migues, wnytaxman, wolfpack21643, Zadnichek
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
